Webcast-Catalyst9k
Transparent bridging on E1 G703 and 802.1Q
hi,
I have several questions (I'm using cisco 1760 router with a VWIC-2MFT-G703 on each site A and B):
Is it possible to aggregate the two G703 links with transparent bridging ?
I have VLAN with STP on each site. Will the 802.1Q frames be forwarded through the "aggregated" E1 links ?
how can I make the aggreagation : Multilink PPP or bridge-group circuit ?
If you have a sample config, thanks to post it.
thanks in advance.
Re: Transparent bridging on E1 G703 and 802.1Q
Not sure with the G703 and aggregating them with bridging but the 802.1Q frame will not propagate to that E1 link aggregated or not.
So do you know another way I can use to interconnect to remote ethernet LAN with the following prerequisite :
- Two cisco router 1760
- Two E1 G703 interfaces on each router (for redundancy and load balacancing).
- VLAN (802.1q) and spanning tree on each site
- We don't want to use a routing process between the two remote LAN.
194
