transparent smtp redirection
In an exhibition center, in order to avoid changing customers' SMTP server configuration , I would like to redirect all SMTP traffic to ours servers transparently. We used to do this using BIGIP LB but we do not want to use them anymore.
Is there a way to do that using Cisco routers and switches?
(7206 VXR, 6506)
thanks
Luc
1 REPLY
Silver
Re: transparent smtp redirection
With policy rotuing this is possible.Route Map is used for this purpose.Each entry in a route map statement contains a combination of match and set clauses/commands. The match clauses define the criteria for whether appropriate packets meet the particular policy (that is, the conditions to be met). The set clauses than explain how the packets should be routed once they have met the match criteria.Refer the following scenario from the URL http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a008009481d.shtml
170
