Community Member
Tricky NAT over GRE configuration. Could use some advice
I recently received a request to setup a GRE tunnel with a vendor for a POC. I have setup the tunnel on my edge Cisco router and can ping the vendor's server, so the tunnel works. The problem is their node is on a subnet overlaps with ours. So to make it work I figured I'm going to have to do some sort of NAT. Here are the particulars:
Our side:
172.16.0.0/16 - Users
10.0.0.0/16 - Users
Their side:
172.16.100.10 - Node
I figure I can NAT 172.16.100.10 to 192.168.100.10 on our edge router and have our users try and connect using the 192.168.100.10 address. So I'm guessing I would have to have this NAT command go against the inside interface so it can NAT the traffic and pass it through the tunnel. Can this work? Would I put my commands on the tunnel interface or the inside interface?
254
