10-17-2006 10:36 PM - edited 03-03-2019 02:23 PM
On my Cisco Router's serial interface, I do a nmap from outside on the Internet. The result is:
" Interesting ports on *.*.50.1:
Not shown: 1676 closed ports
PORT STATE SERVICE
23/tcp filtered telnet
135/tcp filtered msrpc
1524/tcp filtered ingreslock
27665/tcp filtered Trinoo_Master
I am worried about the last two entries. The last nmap was done in Feb this year and I have confirmed that the two ports did not exist.
Though the state "filtered" is a solace but I am still concerned. How can O be sure that the system has not been compromised?
Please Advise!!
Solved! Go to Solution.
10-20-2006 03:41 PM
If it is in a filtered state as said need not be worried.Because Filtered means that a firewall, filter, or other network obstacle is covering the port and preventing nmap from determining whether the port is open.
10-20-2006 03:41 PM
10-23-2006 05:32 AM
This is a nice scenario. Could you please tell us which IOS version you are using and what all filtering commands you have enabled?
Wilson Samuel
