12-29-2006 06:51 AM - edited 03-03-2019 03:12 PM
I needs ideas on how best to go about troubleshooting a link with a very iregular return time. I have checked the LAN and there is no problem and the Service provider also said there is no problem from his side. Please give ideas. Many thanks.
12-29-2006 08:36 AM
check for interface status to see if it is taking CRC/input errors and bandwidth utilization when there is a probelsm. also check in logs if you see any specific messages logged there when problem is being experienced.
12-31-2006 01:45 AM
From the Log i noticed a high fragmentation, no broadcast, packet recieved is more than packet sent, when running a continuos pinging with 104 load on it , it latency will stable for a while at interval it shoots up and come down.
Or is there any way/commend you felt i should i should use and what are the things i should observe.
Thanks for the intrest in my case.
01-01-2007 05:03 PM
It looks like the MTU issue, try to check the interfaces (routers, switches, NIC) are configured w/ proper MTU. Moreover, please post the log then we can suggest more.
Or are ping large packet (> 1492 bytes), so it causes fragmentation ?
Hope this helps.
01-04-2007 05:53 AM
The mtu is set on the tunnels alone. The cdp is also disable on all the routers. The netwotk contain around 600 routers and 1000 switches.
below is a config running on one of the branches. Your suggestions are close to what could be the solution but not the solution at the moment.
Building configuration...
Current configuration : 2821 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname xxx
aaa new-model
aaa authentication password-prompt PASSWORD:
aaa authentication username-prompt USERNAME:
aaa authentication login default group tacacs+ local
aaa authentication enable default group tacacs+ enable
aaa authorization console
aaa authorization exec default group tacacs+ none
aaa authorization commands 15 default group tacacs+ none
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 5 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa session-id common
enable secret
username xxx password
ip subnet-zero
ip dhcp excluded-address xxx.xxx.xxx.xxx xxx.xxx.xxx.xxx
ip dhcp pool TRANS_AMADI
network xxx.xxx.xxx.xxx xxx.xxx.xxx.xxx
default-router xxx.xxx.xxx.xxx
domain-name UBAGROUP.COM
dns-server xxx.xxx.xxx.xxx xxx.xxx.xxx.xxx
netbios-node-type h-node
interface FastEthernet0/0
description VGC LINK TO London
ip address xxx.xxx.xxx.15 xxx.xxx.xxx.xxx
no ip route-cache
no ip mroute-cache
duplex auto
speed auto
no cdp enable
interface Serial0/0
ip address xxx.xxx.xxx.1 xxx.xxx.xxx.xxx
no cdp enable
interface FastEthernet0/1
ip address xxx.xxx.xxx.xxx xxx.xxx.xxx.xxx
ip access-group virus in
no ip mroute-cache
duplex auto
speed auto
no cdp enable
interface Serial0/1
no ip address
shutdown
no cdp enable
ip classless
ip route 0.0.0.0 0.0.0.0 xxx.xxx.xxx.xxx
ip tacacs source-interface FastEthernet0/1
no ip http server
ip pim bidir-enable
ip access-list extended virus
deny tcp any any eq 69
deny udp any any eq 445
deny tcp any any eq 445
deny tcp any any eq 444
deny udp any any eq 444
permit ip any any
no cdp run
tacacs-server host ip tacacs source-interface FastEthernet0/1
no ip http server
ip pim bidir-enable
permit ip any any
no cdp run
tacacs-server host xxx.xxx.xxx.xxx
tacacs-server key cisco
snmp-server view Subview system excluded
snmp-server view Subview cisco excluded
snmp-server view Subview system.1 included
snmp-server view Subview system.2 included
snmp-server view Subview system.4 included
snmp-server view Subview system.5 included
snmp-server view Subview system.6 included
tacacs-server host 10.0.12.65
01-04-2007 09:20 AM
Can you elaborate the meaning of "close to the solution" ? Can you tell the update result and provide the show interface at local & remote router ?
Moreover, I suspect the difference of no. of packet may be the restransmission.
