04-28-2012 07:18 AM - edited 03-04-2019 04:11 PM
Hi Experts
i have some branches connected over E1s Lines , now they are working properly,later on how to troubleshooting these E1s
thanks
jamil
04-28-2012 09:10 AM
Jamil,
Like Paolo stated, there's really nothing to troubleshoot unless you're having an issue...which we all hope you never have
John
04-28-2012 10:07 AM
Guys , but the encap is PPP
04-28-2012 10:13 AM
If the circuit is up though, there's no need to troubleshoot anything if there aren't any problems. If you're just wanting to see if there are errors, you can do a "sh int
HTH,
John
04-28-2012 10:42 AM
Thanks John
04-28-2012 11:06 AM
Encapsulation.doesn't matter. If it works before but not after, is telco fault.
Also, do not low rate posts that are 100% correct just because they don't suit you. That will only make so that professionals on this forum will know how to deal with your questions in the future.
To partially compensate, I've rated it again.
