Webcast-Catalyst9k
trunk across metro-e
Is there typically something that has to be done to enable a trunk when being done across a metro ethernet link? I have two switches that I set up that trunk fine when connected with a crossover but will not trunk when connected over the metro-e. I can send traffic if i set the ports to a non-trunk access with a single vlan.
1 REPLY
Hall of Fame Super Silver
Re: trunk across metro-e
Hello Mike,
ask your Metro ethernet provider for an 802.1Q tunnel and/or check the type of service they are giving you.
Hope to help
Giuseppe
152
