Community Member
trunk on 2600 router
dears,
i have 2610xm router when i want to define the encapsulation on fastethernet 0/0.1 and 0/0.2 intefaces i didn't find the encpsuation command . and when i want to add ip address i have the following message :
% Configuring IP routing on a LAN subinterface is only allowed if that
subinterface is already configured as part of an IEEE 802.10, IEEE 802.1Q,
or ISL vLAN.
Re: trunk on 2600 router
Dot1q encapsulation is not supported in the IP only feature set. A minimum of IP Plus is required to support this feature.
Let me know if I answered your question,
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Community Member
many thanks hritter
it worked well aftr downloading IP/PLUS
To add to above post, to download IP Plus version, you either need smartnet on your router, or atleast priviliged access to Cisco Software center (CCO Login) if you have smartnet on similar products. Or else you can buy the IP Plus IOS for a couple of 100 dollars.
Community Member
you will need IP Plus to configure encap on sub-interfaces
Cheers
Geoff
Community Member
Hi All,
what is smartnet, and more importantly, how do you know if a device has it.? Cheers.
coolboarderguy...
EDIT:
Ah, google is yr friend...
http://www.cisco.com/en/US/products/svcs/ps3034/ps2827/ps2978/serv_home.html
342
