10-25-2006 02:13 PM - edited 03-03-2019 02:28 PM
I have a 3560 switch that has ports fa0/1 - 24 configured as trunks:
description IP_phone/PC
switchport trunk native vlan 10
switchport trunk allowed vlan 10,100,200
switchport mode trunk
switchport voice vlan 100
no ip address
srr-queue bandwidth share 10 10 60 20
priority-queue out
mls qos trust device cisco-phone
mls qos trust dscp
no mdix auto
spanning-tree portfast
and my uplink to my 3750 configured as an access port:
switchport access vlan 1622
switchport mode access
no ip address
priority-queue out
mls qos trust dscp
From what I have read this is backwards. I would like your thoughts as well as how encap/decapsulation works in this setup. Thanks in advance.
10-25-2006 03:59 PM
Shayne,
It all depends upon your needs. If you need to forward just *one* VLAN between switches, configuring the port in access mode would be the right configuration. If you plan on creating a VTP Server/Client model between switches, then you must trunk the port since you need to forward multiple VLAN information between the 2 devices.
I recommend using the industry standard dot1q as the trunk encapsulation if you want to proceed with trunking between these switches. You may also want to prune VLANs in order to prevent unwanted traffic over this link.
As for the IP_Phone/PC ports, they need to be trunked due to having 2 VLANs (one for data and one for voice).
HTH,
10-26-2006 08:06 AM
Thanks for the reply.
I thought when connecting switches the packets needed to be encapsulated and decapsulated using either dot1q or isl, or is that just for switches other than cisco? What is confusing is that if you trunk the 2 switches you use the command "switchport trunk allow vlan *,*... This clearly states multiple vlans are allowed to pass from switch to switch. I would have expected with the ports in access mode to only allow the vlan assigned to the port "switchport access vlan 1627" in this case only vlan 1627 to pass traffic.
10-26-2006 10:05 AM
Shayne,
When connecting switches *and* forwarding multiple VLANs via the links, packets must be tagged with trunk encapsulation dot1q or isl. However, if you only need to forward one VLAN information and avoid any extra traffic, configuring an access vlan would be the right choice.
This concept applies to any switches, cisco or non-cisco.
If you trunk the 2 switches, all VLANs stored in their respective VLAN DBs will be forwarded unless you use the 'allow vlan' option.
10-26-2006 12:12 PM
If you reference my original post ports 1 -24 are trunks but the link to my 3750 is an access port. What you are saying is the only vlan that should travel over the link is the access port vlan. Yet my access port is carrying 3 vlans from the trunked ports. I am confused?
10-26-2006 12:21 PM
Shayne,
"What you are saying is the only vlan that should travel over the link is the access port vlan."
If you configure a port 'mode access' only one VLAN will be forwarded to the device connected to this port.
If this device, a switch on this case, only services one VLAN - then configuring the uplink port with 'mode access' would be the correct configuration here.
If you want to forward VTP information, you need to configure the port as trunk. From your configuration, it looks like you don't have the need to.
Your current workstation ports need to be configured as trunk since you have voice and data services. Voice resides in a different VLAN and Data resides in another VLAN. Only one copper cable is available for these 2 services/vlans so that's the reason you need to trunk it. But even then, as you see, you have a native VLAN on the trunk which functions are the 'access' vlan. That is done with this command.
