Trunking between sites using G703 Serial cards
We have sites which has basic IP connectivity for supporting the data traffic and other applications and using the WAN connections.
Currently we have got a new requirement to provision a point-to-point tunnel using serial interface and to connect to the MUX for sending radio traffic between sites. Since there is adequate bandwidth on the current WAN links, we planned to use the existing network and to run serial trunk across the sites and to present as an E1 connection at each sites using G703 cards.
In other words, this will be an emulation of an E1 over IP networks and I have tried to search for some sample configurations for this setup and there was not much help. It will be great if some one helps to share some of the links with some sample documents and other suggestions for this scenario.
Raj
1 REPLY
Gold
222
