06-17-2010 09:40 AM - edited 03-04-2019 08:48 AM
I'm running ios version ipvoicek9-mz-24.t. I have the crypto command but only the following commands behind it.
crypto ?
CA
engine
key
pki
I don't have the other commands it takes to create a ipsec tunnel.
What am I missing? or Does this IOS not support it?
Solved! Go to Solution.
06-17-2010 02:53 PM
You have an IP Voice IOS, so that's only for telephony.
I will recommend an Advanced IP Services which will provide support for both voice and security.
Federico.
06-17-2010 10:21 AM
The IOS does not support IPsec tunnels.
You have the crypto commands but only to enable SSH and other functions.
You need an advanced security IOS for example.
Federico.
06-17-2010 02:48 PM
Do you know of a IOS that supports both
voice and advanced security (ipsec tunneling)?
06-17-2010 02:53 PM
Federico.
