Webcast-Catalyst9k
Trying to get a DS3 circuit on a GSR12000 to connect to a Nortel SR 4134
Has anyone accomplished this. The code version of 10.1 on the Nortel device does not allow me to change the DSU settings or scramble. I have tried all combination on the Cisco side. Any help would be apprecciated.
Steve
1 REPLY
Hall of Fame Super Silver
Re: Trying to get a DS3 circuit on a GSR12000 to connect to a No
Hello Steve,
this can help you:
http://www142.nortelnetworks.com/techdocs/SR4134_10.1/pdf/NN47263-301_02.01_INS.pdf
it tells to use only the default framing of C-bit because the interface doesn't support M13 framing format
So try to configure the GSR's DS3 accordingly.
Hope to help
Giuseppe
109
