Community Member
Tunnel public traffic over a private wan link DR Scenario
Site A
Public internet router (x.x.x.x) goes to firewall public facing hosts static nated through firewall on dmz interface.
Connected to Site B with WAN link separate router.
Site B
Public internet router (y.y.y.y) goes to firewall. Site only used for outbound internet access. Connected to Site A with WAN Link separate router.
Can I do the following.
Connect Site A public router to Site A WAN router. Connect Site B public router to Site B WAN router. "Tunnel" BGP rerouted x.x.x.x traffic from Site B to the Site A public router.
This is in the event that Site A loses internet and x.x.x.x network fails over to site B. Assuming Site A is perfect other than internet I would like to know if this is doable. The idea is that I need the traffic to show up clean on Site A outside firewall interface just as if it originated from the Site A public router. It of course would have to use the tunnel on the way back as well for ther return traffic or outbound traffic originating from Site A. Thanks a bunch.
1 REPLY
Bronze
Re: Tunnel public traffic over a private wan link DR Scenario
Like the edge configurations, the BGP instance at this layer is what peers the protocol to the upstream
edge layer and receives its default route to the upstream Internet edge layer.
The following URL may help you:
http://www.cisco.com/en/US/solutions/ns340/ns517/ns224/ns304/net_design_guidance0900aecd800eb958.pdf
111
