Community Member
Tunnel transmit bandwidth 8000
Could anyone tell me why the Tunnel bandwidth send/recieve is set to 8000kbps?
I have a 20Mb circuit here and I would like the tunnel to be able to consume all of it. Is there a command to do this?
Tunnel0 is up, line protocol is up
Hardware is Tunnel
Description: IPSEC/GRE Tunnel to WH
Interface is unnumbered. Using address of FastEthernet1/1 (x.x.x.x)
MTU 1514 bytes, BW 9 Kbit, DLY 500000 usec,
reliability 255/255, txload 1/255, rxload 28/255
Encapsulation TUNNEL, loopback not set
Keepalive not set
Tunnel source x.x.x.x (FastEthernet1/1), destination x.x.x.x
Tunnel protocol/transport GRE/IP
Key disabled, sequencing disabled
Checksumming of packets disabled
Tunnel TTL 255
Fast tunneling enabled
Path MTU Discovery, ager 10 mins, min MTU 92, MTU 0, expires never
Tunnel transmit bandwidth 8000 (kbps)
Tunnel receive bandwidth 8000 (kbps)
Last input 00:00:03, output 00:00:25, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 5372
Queueing strategy: fifo
Output queue: 0/0 (size/max)
5 minute input rate 1000 bits/sec, 1 packets/sec
5607085 packets input, 1295617062 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
183454 packets output, 28171753 bytes, 0 underruns
Any help rated.
Gavin
1 REPLY
Re: Tunnel transmit bandwidth 8000
Hi Gavin
You can define the same using tunnel bandwidth recieve/transmit command.
you can also verify the below link for more info..
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_command_reference_chapter09186a00801a7ea2.html#wp1161607
regds
1731
