Tunnel with IP Address 172.16.0.1 on ASR1002/ASR1006
tarun_ladkani
Hi team,
Does anyone know why do we see Tunnelx with IP Address 172.16.0.1 on ASR1002/ASR1006 even though not having configured it?
10 Replies 10
which kind of tunnel it is?
BR
Thanveer
Tunnel1 and Tunnel2 .. The tunnels are NOT present in running or Starting configs.
But "show ip interface brief" output shows the tunnels Tu1, and Tu2 configured with 172.16.0.1 IP address.
Same case with Tu0 ... But at least the Tu0 picks an IP address that I know is configured on one of teh router interfaces.
 I will try check in my box too, but before this let me know the ios version
It is RP1 IOS for ASR1002
asr1000rp1-adventerprisek9.03.01.04a.S.150-1.S4a.bin
For ASR1006 it is the corresponding RP2 version.
I have over a dozen of such instances across my network ... In all cases these Tunnels were NOT configured by us and they don't show in teh Startup / Running configs at all.
My IOS version is asr1000rp2-advipservicesk9.03.11.00.S.154-1.S-std.bin, I am having no issues.
Is it possible that you can upgrade any one of the boxes and check. better you upgrade with 15.3(3)S2 version as IOS version which I am also having a bug id, it shows the Actual ACTV/STBY LED state is incorrect
BR
Thanveer
I have checked it in my ASR 1006 box, I haven't found anything strange, here.
Please provide the IOS version  which you are using on the box.If you are sure that none of your team has configured it then it might be an IOS bug.
Has the original poster perhaps configured WCCP on his router? In some configurations WCCP will automatically generate GRE tunnels and pick an IP address for the tunnel.
Rick
Rick
Might be sir
Might be Sir.
