Community Member
Tunnel wont come up unless outside nat int is denied
When setting up a nat we did have problems with the GRE tunnel coming up in an 861.  Below is the config before it was working.
interface Tunnel16
description TUNNEL_TO_HQ
ip address 10.1.1.1 255.255.255.252
ip mtu 1400
ip tcp adjust-mss 1360
keepalive 10 3
tunnel source X.X.X.X
tunnel destination Y.Y.Y.Y
ip nat inside source list NAT_INTERFACE interface FastEthernet4 overload
ip nat inside source static tcp X.X.X.X 22 interface FastEthernet4 22
ip nat inside source static tcp X.X.X.X 23 interface FastEthernet4 23
ip route 0.0.0.0 0.0.0.0 X.X.X.X
ip route 10.0.0.0 255.0.0.0 Tunnel16
ip route 172.16.0.0 255.255.0.0 Tunnel16
ip route 192.168.0.0 255.255.0.0 Tunnel16
ip access-list extended NAT_INTERFACE
deny   ip any 10.0.0.0 0.255.255.255
deny   ip any 172.16.0.0 0.0.255.255
deny   ip any 192.168.0.0 0.0.255.255
permit ip any any
The above config would work on every 861 router we tried that was below 15.0  We applied the above config to a 15. router and the tunnel would always stay up/down.
We ended up entering the below statement in the access which fixed the problem.
deny   ip host X.X.X.X any  **This is the outside interface address
permit ip any any
I'm unsure why this is nessasary and why it ended up working.
146
