Tunnels going down at a particular time daily
palukuri77
We do have an IPSec tunnels created on a 2621 router. Recently we are facing a problem. The EIGRP relationship (the Tunnels) are going down at a particular time every day (around 10:45 am local time daily)
The configuration on the router is as follows:
Router_IPsec#sh runn
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
crypto isakmp key Tzoombie2b0r@$2b!t0moru& address x.x.x.x
crypto isakmp key Lom!LurmlOM!lURMbozodeeclown address x.x.x.x
crypto ipsec transform-set myset-3des esp-3des esp-md5-hmac
crypto ipsec transform-set myset-3des-comp esp-3des esp-md5-hmac comp-lzs
crypto map vpn 20 ipsec-isakmp
description IPSEC Tunnel to Bracknell -Backup path
set peer x.x.x.x
set transform-set myset-3des
match address 120
crypto map vpn 30 ipsec-isakmp
description ipsec tunnel to Boston
set peer x.x.x.x
match address 130
interface Loopback0
description Ipsec Tunnel to Bracknell - Backup path
ip address 131.101.83.166 255.255.255.255
interface Loopback1
ip address 131.101.83.43 255.255.255.255
interface Tunnel0
description IPSEC Tunnel to Bracknell - Backup path
ip unnumbered FastEthernet0/0
ip accounting output-packets
ip mtu 1400
ip policy route-map clear-df
keepalive 3 3
tunnel source Loopback0
tunnel destination 131.101.83.167
interface Tunnel1
ip mtu 1400
load-interval 30
keepalive 3 3
tunnel source 131.101.83.43
tunnel destination 131.101.83.42
interface FastEthernet0/0
description Munich LAN subnets
ip address 131.101.228.253 255.255.255.0 secondary
ip address 131.101.192.253 255.255.255.0
ip route-cache flow
speed 100
full-duplex
interface FastEthernet0/1
description DSL connection to internet
ip address x.x.x.x 255.255.255.248
ip route-cache flow
duplex auto
speed auto
crypto map vpn
router eigrp 101
redistribute connected
passive-interface FastEthernet0/1
network 131.101.0.0
distribute-list 10 out Tunnel0
distribute-list 20 out Tunnel1
distance 180 131.101.50.235 0.0.0.0
no auto-summary
ip route 131.101.83.42 255.255.255.255 x.x.x.x
ip route 131.101.83.167 255.255.255.255 x.x.x.x
ip route 198.51.251.194 255.255.255.255 x.x.x.x
ip route 212.133.24.86 255.255.255.255 x.x.x.x
access-list 10 permit 131.101.192.0 0.0.0.255
access-list 10 permit 131.101.193.0 0.0.0.255
access-list 10 permit 131.101.228.0 0.0.0.255
access-list 20 permit 131.101.192.0 0.0.0.255
access-list 20 permit 131.101.228.0 0.0.0.255
access-list 30 permit 131.101.192.0 0.0.0.255
access-list 40 permit 131.101.228.0 0.0.0.255
access-list 104 permit ip any any
access-list 120 remark Bracknell GRE Tunnel
access-list 120 permit gre host 131.101.83.166 host 131.101.83.167
access-list 130 permit gre host 131.101.83.43 host 131.101.83.42
route-map clear-df permit 10
match ip address 104
set ip df 0
Actually this setup is working fine for quite some days and we are even tracking the internet link which has no drops at all. But only the tunnels are going down at times on this router that too like a planned periodic time (daily 10:45 a.m. local time)
Please help me out asap.
dkeaton
What are your IOS versions? We had something similar happen when we had 12.4... connecting to 12.3... Do you have the same keepalive configured on both sides? Do you have the problem if you take the keepalive off of your GRE tunnel interfaces? I have also experienced similar issues when using CEF on my public interface.
gtambour
Hi, here is someting that we use on our tunnels for intermittent EIGRP relationship transitions. You can give it a try. It has to be configured on both ends of the connection.
interface Tunnel22
ip address xxxxxxxxxxxx
ip tcp adjust-mss 1370 - set the mtu without ip header to 1370 (this eliminates fragmentation)
ip hello-interval eigrp xxxx 10 - lower the number of eigrp transitions that are frequent on VPN links
ip hold-time eigrp xxxx 120 - lower the number of eigrp transitions that are frequent on VPN links
tunnel source Loopback100
tunnel destination xxxxxxxxx
crypto map vpn
