09-24-2006 09:39 PM - edited 03-03-2019 02:06 PM
hi
We have a situation where an old SMS server system needs to communicate to other servers via PSTN. I was told to figure out a way to relay these signals through the wan. What I need to do is to connect the server via an RS232 cable to a router (on a port or a module of some sort) and packetize the signals,send it through the WAN and do the reverse in the branch office so that these servers can communicate.
Is this possible? Does any one have an idea?
thanks in advance.
09-25-2006 11:32 AM
A terminal server is a device that converts RS232 to packets (usually TCP). One side connects to a serial port and the other side is Ethernet. A quick Google search turned up this one:
http://www.perle.com/products/IOLAN-DS-Terminal-Server.shtml
Please rate helpful posts.
09-25-2006 12:19 PM
We use "Lantronix" terminal servers with great success. They configure very easily and simply hang off of a switchport.
Here is the link to their site:
http://www.lantronix.com/device-networking/external-device-servers/
Brian
09-25-2006 11:11 PM
I was actually thinking of using the router some how for this case.
Thanks any way
