Community Member
two bgp as
Is it possible to have two different BGP AS in the same router?
Thank's
Marcelo
1 ACCEPTED SOLUTION
Re: two bgp as
Marcelo,
You cannot use this command on an iBGP peer. You can inverse the logic though, change your "router bgp" ASN to 65200 and use the local-as command on the peer to ASN 11664 instead as follow:
router bgp 65200
neighbor 77.1.248.25 remote-as 65200
neighbor 154.0.17.129 remote-as 11664
neighbor 154.0.17.129 local-as 65194 no-prepend replace-as
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Hall of Fame Super Gold
Re: two bgp as
Yes, in a kind of virtual manner. That is because you can manipulate AS numbers in any way you want.
Community Member
Re: two bgp as
Thank's
Can you tell me some link with an example?
Marcelo
Highlighted
Re: two bgp as
Are you familiar with BGP configuration and AS path manipulation ? All that is documented in the cisco manuals.
That is the pre-requisite for what you want to do.
Re: two bgp as
Marcelo,
You might want to check the following example.
http://www.cisco.com/en/US/docs/ios/12_4t/ip_route/configuration/guide/brbpeer.html#wp1126960
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Community Member
Re: two bgp as
I applied this configuration but I can't get the peering. There is the following error:
Jun 11 10:38:04: %BGP-3-NOTIFICATION: sent to neighbor 77.1.248.25 3/11 (invalid or corrupt AS path) 3 bytes 400200
Re: two bgp as
Marcelo,
Can you send a bit more info about the topology and configuration that you are trying to implement.
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Community Member
Re: two bgp as
This is the configuration. I need peering with 2 differente AS. The AS 65200 see me as 65200 y de 11664 see me as 65194.
router bgp 65194
no synchronization
bgp log-neighbor-changes
redistribute connected
neighbor 77.1.248.25 local-as 65200 no-prepend replace-as
neighbor 154.0.17.129 send-community
no auto-summary
Re: two bgp as
Marcelo,
router bgp 65200
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Community Member
Re: two bgp as
Thank's Hritter. Your answer resolved my issue.
Marcelo
Re: two bgp as
Marcelo,
You can only assign one AS number to your BGP router process but you can change that AS number when you connect to BGP peers by using the local-as feature.
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
593
