Webcast-Catalyst9k
Two Cisco and two FW clustered
Escenario:
1) Cisco 1941 and Cisco 1841 connected in cluster by HSRP and  both of them having two LAN cards each one,
  Cisco 1941 has  Ge 0/1  + another LAN card     And  Cisco   1841 has  Fe  0/1  + Another LAN  card
2) Two Link or Load  Balancing Appliances also having inside FireWallI enable, connected in cluster between them,  (FW1   and   FW2)
   both of them have four  WAN,  (Wan1, Wan 2, Wan3, Wan4)  for distribuiting Upload traffic in a load balanced mode (Generally used for Adsl Backup)
If   i connect directly       Cisco 1941  Ge 0/1     To  FW1  Wan1  port    and second LAN card of Cisco 1941 To  FW2   Wan1 port
Then  i connect dierctly   Cisco 1841 Fe 0/1     To  FW1  Wan2  port    and  second LAN card of Cisco 1841 To FW2   Wan2 port
  If  FW1 fails,  and traffic is redirected to FW2 (clustered)  Automatically from the LAN direction
Question:
  Will  Cisco  1941 (the Main router one)  send traffic Automatically using Its Second LAN card to  FW2, or is there option ?
    (Because Ge 0/1 connected to FW1  won't work as FW1 is failure)
201
