Webcast-Catalyst9k
Two Cisco routers using EIGRP and the same won't exchange routing updates
I have 2 cisco routers (2621 IOS 12.2(5), 2821 IOS 12.4.7) that are connected to the same LAN segment. Both routers are running IP routing via EIGRP. both EIGRP processes are suing the same AS (100). (this config is a transitional one as we move fropm the 2621 to the 2821).
The issue is that the 2821 does not receive routing updates from the 2621. It does not even see the 2621 as an EIGRP neighbor. Mean while the 2621 does see the 2821 as a neighbor.
The two routers can see each other, and if I set a static default route on the 2821 I can route out from the 2821 to anywhere\any network on the rest of the WAN network.
A brief layout of the connections:
[Active WAN] -- [S0/0.1 (2621) FE 0/0.1] -- [FE 0/1 Trunk Cat2950 switch FE 0/4 Trunk] -- [GE 0/0.1 (2821) S 0/0/0.200] -- [Furture WAN]
Both both interfaces on the routers are configured to be on Native VLAN 1 using dot1q encapsulation.
I have used this configuration at several other sites as a transitional with any issues. So I'm either to close to the problem and am being blind or something weird is going on. :)
The router configurations are:
----2621
interface FastEthernet0/0
no ip address
speed 100
full-duplex
no mop enabled
interface FastEthernet0/0.1
description VLAN-1 PMI General Network
encapsulation dot1Q 1 native
ip address 172.16.31.1 255.255.255.128
ip pim sparse-dense-mode
ip cgmp
interface Serial0/0
description WAN Connections
no ip address
no ip proxy-arp
encapsulation frame-relay IETF
logging event subif-link-status
logging event dlci-status-change
no fair-queue
interface Serial0/0.1 multipoint
description Frame-Relay PMI-LTN 256 kb Primary
bandwidth 256
ip address 172.16.20.130 255.255.255.252
cdp enable
frame-relay map ip 172.16.20.129 308 broadcast
router eigrp 100
network 172.16.0.0
network 172.17.0.0
network 172.18.0.0
no auto-summary
eigrp log-neighbor-changes
ip classless
--- 2821
interface GigabitEthernet0/0
no ip address
duplex full
speed 100
interface GigabitEthernet0/0.1
ip address 172.16.31.4 255.255.255.128
no snmp trap link-status
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
no ip address
interface Serial0/0/0.200 point-to-point
ip address aa.bb.cc.dd 255.255.255.252
frame-relay interface-dlci 200 IETF
router eigrp 100
network 172.16.0.0
no auto-summary
Some information from the 2821 router:
PMI-2821-1#sh ip eigrp traff
IP-EIGRP Traffic Statistics for AS 100
Hellos sent/received: 3251/0
Updates sent/received: 0/3100
Queries sent/received: 0/0
Replies sent/received: 0/0
Acks sent/received: 0/0
Input queue high water mark 1, 0 drops
SIA-Queries sent/received: 0/0
SIA-Replies sent/received: 0/0
Hello Process ID: 210
PDM Process ID: 208
Re: Two Cisco routers using EIGRP and the same won't exchange ro
Hello just for your information:
most common causes of problems with EIGRP neighbor relationships:
l Unidirectional link
l Uncommon subnet, primary, and secondary address mismatch
l Mismatched masks
l K value mismatches
l Mismatched AS numbers
l Stuck in active
l Layer 2 problem
l Access list denying multicast packets
l Manual change (summary router, metric change, route filter)
do you see hello packets coming from each neighbor on the ethernet interfaces?
debug ip eigrp packet hello
If you ping 224.0.0.10 what do you see? this will check multicast on this segment.
Let us know,
Vlad
The result of the ping 224.0.0.10 on the 2821 router:
PMI-2821-1#ping 224.0.0.10
Sending 1, 100-byte ICMP Echos to 224.0.0.10, timeout is 2 seconds:
Reply to request 0 from pmi-2621-1-fe0-0-1.alteontraining.com (172.16.31.1), 1 ms
The output from a sh ip eigrp traffic on the 2821 router:
Hellos sent/received: 4702/0
Updates sent/received: 0/4478
PDM Process ID: 208
The output from a sh ip eigrp traffic on the 2621 router:
IP-EIGRP Traffic Statistics for process 100
Hellos sent/received: 609116/106544
Updates sent/received: 94243/112
Queries sent/received: 121/68
Replies sent/received: 67/68
Acks sent/received: 229/226
Input queue high water mark 2, 0 drops
Results for debug EIGRP packet hello and EIGRP neighbor (2821 router):
*Jun 8 01:08:27.978: EIGRP: Sending HELLO on GigabitEthernet0/0.1
*Jun 8 01:08:27.978: AS 100, Flags 0x0, Seq 0/0 idbQ 0/0 iidbQ un/rely 0/0
*Jun 8 01:08:29.974: EIGRP: Neighbor(172.16.31.1) not yet found
Results for debug EIGRP packet hello and EIGRP neighbor (2621 router):
5d07h: EIGRP: Sending HELLO on FastEthernet0/0.1
5d07h: AS 100, Flags 0x0, Seq 0/0 idbQ 0/0 iidbQ un/rely 0/0 all
5d07h: EIGRP: Sending HELLO on FastEthernet0/0.2
5d07h: EIGRP: Sending HELLO on FastEthernet0/0.4
5d07h: EIGRP: Received HELLO on FastEthernet0/0.1 nbr 172.16.31.4
5d07h: AS 100, Flags 0x0, Seq 0/0 idbQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/7
The are also the following console messages being displayed on the 2621 router:
5d07h: %DUAL-5-NBRCHANGE: IP-EIGRP 100: Neighbor 172.16.31.4 (FastEthernet0/0.1) is up: new adjacency
PMI-2621-1#
5d07h: %DUAL-5-NBRCHANGE: IP-EIGRP 100: Neighbor 172.16.31.4 (FastEthernet0/0.1) is down: retry limit exceeded
The 2821 router was originally misconfigured with a bad stbnet mask, but that has ben fixed. Both routers have been restarted since the fix mas made just in cast there was something stuck i memory causing the problem.
I believe that for some reason the hellos from 2621 are not reaching 2821 router.
could you please recheck the ping 224.0.0.10 from 2601, check if you get a response from 2821.
Let me know,
Vlad
Silver
I agree with you about the hellos. Do you have any multicast config on the 2950 switch? These could be blocking the hellos from reaching the 2821. Note that hellos are multicasted.
Also try to remove the CGMP config on the interface and see what happens.
Thanks guys. I resolved the problem.
Following olorunloba's advice I removed the cgmp statment from the interface, but the problem persisted. Then I removed the the "ip pim sparse-dense-mode" statment. Either removing that statment or removing the combination appears to have resolved the issue.
I am now getting routing updates to the 2821 router.
thanks for your help.
1147
