Community Member
two diferent nat in two diferent serial interface
Hi, i have two frame-relay configured in two serial interface. 1 serial interface have now a ip pool nat outside but i need have other pool nat outside diferent in my other interface. I have only a ethernet adapter.
How can i have 2 diferent ip pool in 2 diferent serial???
1 REPLY
Purple
Re: two diferent nat in two diferent serial interface
Try something like this:
ip cef
interface serial0
ip address 255.255.255.252
ip nat outside
interface serial1
ip nat outside
interface Ethernet0/0
ip address 10.1.1.1 255.255.255.0
ip nat inside
ip route 0.0.0.0 0.0.0.0 serial0
ip route 0.0.0.0 0.0.0.0 serial1
ip nat pool POOL1 netmask
ip nat pool POOL2 netmask
ip nat inside source route-map ISP1-map pool POOL1
ip nat inside source route-map ISP2-map pool POOL2
route-map ISP11-map permit 10
match interface serial0
route-map ISP12-map permit 10
match interface serial1
Hope that helps - pls rate the post if it does.
Paresh
87
