12-09-2006 10:03 AM - edited 03-03-2019 02:58 PM
I wish to put two routes different towards a same destiny in the router.
if one of these routes fails the other it works?
As I determine the priority between these routes ?
Greetings
12-09-2006 10:07 AM
It would be helpful if you provide the IP Schema for a better understanding....
JD
12-09-2006 09:53 PM
Hi ,
You can have two routes for the same destination if you have two outbound interfaces .
You can set the priority for the two routes by setting a diff metric for the two routes.
eg :
ip route x.x.x.x mask s0
ip route x.x.x.x mask s1 200 --- Secondry route
Hope this helps
regards
vanesh k
12-10-2006 10:11 AM
as suggested in earlier post, you can configure floatic static routes for this.
ip route 0.0.0.0 0.0.0.0 s0/0
ip route 0.0.0.0 0.0.0.0 s0/1 200
since administrativr distance of route via s0/1 is higher than the administrative distance of route via s0/0, route via s0/0 will be installed in the routing table. If interface s/0 goes down, routing table will install route via s0/1 and vice-versa.
hope it helps .... rate if it does ....
12-11-2006 06:39 AM
Thank you very much
