05-28-2014 02:26 PM - edited 03-04-2019 11:03 PM
How to connect Two ISP to single Router and configuration???
Solved! Go to Solution.
05-28-2014 03:39 PM
Hey Ganesh,
You may use any protocol, however first check with your service providers about which protocol they are using.
However most of times itsBGP, so here is a good documentation for same:
http://www.cisco.com/c/en/us/support/docs/ip/border-gateway-protocol-bgp/23675-27.html
HTH.
RS
05-28-2014 03:39 PM
Hey Ganesh,
HTH.
RS
05-30-2014 12:39 PM
Thank you
05-30-2014 01:22 PM
Cheers :)
RS
05-29-2014 02:56 AM
can you elaborate the purpose of this yes BGP is usually used or if you just want to use the link for internet trafiic and load balancing you can use the ip sla with track option to achieve this .
