Two metric in BGP into EIGRP redistribution
Hi, I want to redistribute BGP routes into EIGRP, but I want to segregate EIGRP metric. Below line is already configured. I have to add prefix-list "irvine-routes" which should be carry lower metric to EIGRP neighbor devices.
Please confirm what would be the effect as 1544 1 255 1 1500 is already configured in Bgp into Eigrp redistribution for all routes of bgp-to-eigrp permit 20.
router eigrp 1
redistribute bgp 65461 metric 1544 1 255 1 1500 route-map bgp-to-eigrp
route-map bgp-to-eigrp permit 10
match ip address prefix-list irvine-routes
set metric 1100 1 255 1 1500
route-map bgp-to-eigrp permit 20
Hall of Fame Super Silver
Re: Two metric in BGP into EIGRP redistribution
Hello Rupesh,
if you want to provide a lower seed metric for this subset you need to use an higher BW parameter because EIGRP metric is inversely proportional to min BW on path.
add a line
default-metric 1544 1 255 1 1500
and rewrite the current comand as:
redistribute bgp 65461 route-map bgp-to-eigrp
if you want a better metric use:
set metric 4000 1 255 1 1500
Hope to help
Giuseppe
You mean, I have use total four lines, please confirm if my comments are correct below-
Line-1->> default-metric 1544 1 255 1 1500 ( All route will use this metric except Irvine-route)
Line-2->>  redistribute bgp 65461 route-map bgp-to-eigrp
Line-3->>route-map bgp-to-eigrp permit 10
              set metric 4000 1 255 1 1500 ( It will only applicable for Irvine-route)
Line-4->>   route-map bgp-to-eigrp permit 20 (( All route will use this metric 1544 1 255 1 1500 except Irvine-route)
Hello Rupesh,
yes your understanding is correct.
Hope to help
Giuseppe
what about if I implement following four lines, Is it right way--
Line-1 ->> redistribute bgp 65461 metric 1544 1 255 1 1500 route-map bgp-to-eigrp
Line-3->>
Line-4- > route-map bgp-to-eigrp permit 20
Hello Rupesh,
I cannot test this in this moment however, I don't expect the two commands
to both exist at the same time, so to be correct you need to verify with
sh run | begin router eigrp
what happens
a possible procedure could be:
no redistribute bgp 65461 metric 1544 1 255 1 1500 route-map bgp-to-eigrp
no redstribute bgp 65461
until you don't see any redistribute command with sh run | beg router eigrp
then
I would update the route-map first before applying it.
if the current line is
you may just need to update the route-map and you can skip the default-metric command
if this is not a production network you can do this anytime otherwise it is wise to do it in a maintanance window
Hope to help
Giuseppe
2549
