Two WAN and one LAN connection over PIX.
Could you please help me with the following problem. I whant to conect two Inernet channels from different providers over the PIX. One of the Internet channel I whant to use as the main and another one as the redundant. So the second one will not in use until the first one is working properly, but if the first one will be down the second one should provide Internet connectivity for the LAN hosts. I whant to use static routing and no any routers but the firewall PIX. Is it possible to realize my idea on any of PIX? Thank you. Gregory.
1 REPLY
Re: Two WAN and one LAN connection over PIX.
Similar scenario has been discussed over here where they have taken a reference of different interface and used tracking feature to achieve redundancy.
You can have the same to achieve your requirement tooo..
http://www.cisco.com/en/US/docs/security/asa/asa72/command/reference/qr_72.html#wp1654829
regds
113
