Two WAN connection issues with 877 DSL
I recently switched from cable to DSL, and that change required the addition of a 877 router (IOS 15.1). The internet network is (192.168.0.0/28) that has the old firewall (Linux server) and ASA 5505. On the ASA I have force maximum TCP segment size of 1380, after setting that I have no connection issues. However I have two unique problems that might or might not be related.
First, this 877 has multiple interfaces along with wireless. When connecting to the wireless for example or another interface/subnet (i.e. directly connected to the 877 and not behind the ASA) I have the same issue I had prior to force TCP segment size on the ASA. For example I can do a Google search, but beyond that it would time out. Same behavior so I suspect maybe same issue with segment size on the 877.
Second problem is really peculiar. My mail server, external, has eratic connections. For example Windows mail client connects fine (Zimbra desktop), webmail client (Group Office) connects erratically and often times out, and my Android phone does not connect at all. When I had cable and was behind either the ASA or Linux server I had no issues, change over to the 877 as the gateway changed all that. For some reason my connection to just this specific mail server is problematic. I have another external mail server that is completely different domain and server that I connect to fine.
So here today wondering if anyone can first give me some tips on how I should go about debugging the mail server connection issue. Secondly was wondering if there is anything in my config for the 877 that causes the timeouts. Not knowledgable enough with TCP/IP, but was wondering if I have 1452 set on the router, is that too high? Should I adjust that to also match the ASA as well? I am wondering if something like this is also causing the connection problems to the mail server as well. I can "connect", but not actually establish a full connection as I should.
version 15.1
ip source-route
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
no atm ilmi-keepalive
interface ATM0.2 point-to-point
ip flow ingress
snmp trap link-status
pvc 0/32
  oam-pvc manage
  pppoe-client dial-pool-number 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
switchport access vlan 2
interface FastEthernet3
interface Vlan1
description FW_INSIDE$
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
ip virtual-reassembly in
ip tcp adjust-mss 1452
bridge-group 1
interface Vlan2
description FW_INSIDE_2$
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
bridge-group 2
interface Dialer0
description $FW_OUTSIDE$
ip address negotiated
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname **********
ppp chap password 7 **********
ppp pap sent-username ******* password *******
interface BVI1
description $FW_INSIDE$$FW_INSIDE$
ip address 192.168.0.1 255.255.255.224
ip nat inside
interface BVI2
description $FW_INSIDE2$$FW_INSIDE$
ip address 175.12.10.1 255.255.255.240
ip nat inside
ip nat pool 101 192.168.0.1 192.168.0.30 netmask 255.255.255.224
ip nat pool 102 175.12.10.1 175.12.10.14 netmask 255.255.255.240
ip nat inside source list 101 interface Dialer0 overload
ip nat inside source list 102 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
access-list 1 permit 192.168.0.0 0.0.255.255
access-list 101 permit ip 192.168.0.0 0.0.255.255 any
access-list 102 permit ip 175.12.10.0 0.0.0.255 any
382
