10-03-2007 10:53 AM - edited 03-03-2019 07:01 PM
We've recently made some changes on our UC500 and did not save a configuration. Now all our phones have "configuring IP" message since yesterday. I do not know the fix around this and tried to reset to factory default using the CUE: service-module integrated-service-engine 0/0 session.
Does anyone have any ideas to get around this. I'm totally lost and not very familiar with this UC500.
10-03-2007 10:57 AM
Phone are not getting IP address = DHCP or VLAN issue.
Please describe your setup and config in the "ip telephony" forum.
10-03-2007 11:05 AM
10-03-2007 11:10 AM
Telnet to the router, do show run, copy & paste into .txt file, attach file in forum message.
Please use the "ip telephony" forum for CCME related questions.
10-03-2007 11:32 AM
10-03-2007 12:05 PM
a large piece of config is missing. I suggest you use putty (free software) for easy cut & paste.
Anyway, you should have something like "ip dhcp pool xxx" at the beginning. Make sure the parameters matches CME ethernet address, and there is an "ip option 150 x.x.x.x" again with router address. This will actually give phones the address of the CME to connect to.
You can access Ip telephony forum from the "Unified communication and video" link on the left side of the screen.
