unable to copy run FTP (VRF Aware)
fasikaasresu
                   my interface is in a specific VRF
interface Loopbackx
  ip vrf forwarding  MGMTxxx
ip address xxxxxxxxxx
and the
global
comand
ip tftp source-interface Loopbackx
is also enable
the problem is
though I can ping to the ftp server
and I can telnet to the ftp server using port 21
I am not able to copy
run tftp/....../sublocation/
any help is apreciated
jai_chandra2001
i tried
copy ftp://username:password@1.1.1.1 bootflash:  vrf <vrf name>
and it worked on 4500 switch
6 Replies 6
Hello.
you are copying file via FTP, but configured source-interface for TFTP.
If the guess is wrong, could you please share your configuration and failed attempt output?
PS: FTP is using TCP 21/20, TFTP is using UDP 69. Btw, you might need to configure FTP as passive (ip ftp passive) to use TCP 21 only, because TCP20 could be blocked somewhere.
Hello
On the source router is tftp or FTP enabled?
Tftp server xxxxx
Ip ftp username xxxx
ip ftp password xxx
ip ftp passive
ip ftp source-interface xxx
Res
Paul
Kind Regards
Paul
jai_chandra2001
i tried
This solution works on 9300 as well, Thank you Jai...
You can also set the
to the interface configured on the associated vrf. (you can do this in the global configuration mode)
craiglong
If you're having this problem on a device that doesn't support the vrf option at the end of the
copy
command, try just sourcing the ftp traffic from the interface that's in the vrf.
For example, on a 3850, the Managment port, Gi0/0, is in the Mgmt-vrf by default and can't be changed.  Since I didn't have an option to use the vrf at the end of the
copy
command like you can on a 4500, I just did an
ip ftp source-interface Gi0/0
and the
copy
command knew to use that Mgmt-vrf vrf to access the ftp server.
