Community Member
Unable to ping or traceroute from LAN Core Switch to WAN router
I'm having a problem trying to ping from LAN core switch to the router. What could be the possible causes ?
Re: Unable to ping or traceroute from LAN Core Switch to WAN rou
HI Joseph, [Pls Rate if HELPS]
>> Confirm whether you LAN Traffic can reach the destination via Router
>> Trace to the Router and check whether the trace completed
>> See in Router whether any ICMP Block has been configured for the LAN Switch IP Segments
Guru Prasad R
Hi JOSEPH, can you post the traceroute output as well as extended ping's output. Thanks Goutam
Community Member
Hi Friend,
Can u pls tell me ur switch model number and default route .. pls check also static route from switch to router and router switch.
send me also trace route result from switch 2 router and router 2 switch.
Silver
Kind of hard to assist without knowing how you are connected.
Is the switch directly connected to the router?
Is the interface us?
Are you trunking between the Router and Switch?
Do you have the correct encapsulation between the two?
What is the set-up and what is desired?
Community Member
There are Riverbed and Packet Shaper in between the switch and router. From the PS, I can ping and trace route to both the switch and router. So, the logical connection is something like below:
LAN Core SW ->Riverbed -> Packet Shaper -> Router
sw01>ping 23.252.254.116
Sending 5, 100-byte ICMP Echos to 23.252.254.116, timeout is 2 seconds:
Success rate is 0 percent (0/5)
sw01>
sw01>sh ip ro 23.252.254.116
Routing entry for 23.252.254.112/29
Known via "connected", distance 0, metric 0 (connected, via interface)
Routing Descriptor Blocks:
* directly connected, via FastEthernet3/3
Route metric is 0, traffic share count is 1
sw01>sh int FastEthernet3/3
FastEthernet3/3 is up, line protocol is up (connected)
Hardware is C6k 100Mb 802.3, address is 0007.b355.5000 (bia 0007.b355.5000)
Description: rt05 fa0/0 (Through Riverbed/Packershaper)
Internet address is 23.252.254.115/29
rt05#ping sw01
Sending 5, 100-byte ICMP Echos to 10.100.29.190, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
rt05#sh ip ro sw01
Routing entry for 10.100.29.190/32
Known via "ospf 49", distance 110, metric 2, type intra area
Last update from 23.252.254.115 on FastEthernet0/0, 01:22:45 ago
* 23.252.254.115, from 10.100.29.190, 01:22:45 ago, via FastEthernet0/0
Route metric is 2, traffic share count is 1
523
