Unable to ping remote LAN from PE
I have a new MPLS connection and the setup is completed. I am able to ping from CORE_Router to CORE_ROUTER_QAT, however I am not able to ping LAN on both the sides. Below is the layout.
CORE_ROUTER carries the following configuration :
version 15.1
hostname CORE_Router
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
no ipv6 cef
ip source-route
ip cef
no ip domain lookup
ip name-server 84.235.x.x
crypto pki trustpoint TP-self-signed-144954112
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-144954112
revocation-check none
rsakeypair TP-self-signed-144954112
crypto pki certificate chain TP-self-signed-144954112
certificate self-signed 01
  xxxxx
        quit
license udi pid CISCO2911/K9 sn FCZ154670GK
interface Loopback0
ip address 20.20.20.20 255.255.255.0
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.2400
description $STC_DIA6$
encapsulation dot1Q 2400
ip address 84.235.x.x 255.255.255.252
ip nat outside
ip virtual-reassembly in
interface GigabitEthernet0/1
description $VPN_LAN$
ip address 128.1.0.100 255.255.255.248
duplex auto
speed auto
interface GigabitEthernet0/2
description $WAN_LAN$
ip address 84.235.x.x 255.255.255.240
ip nat inside
duplex auto
speed auto
interface FastEthernet0/0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0/0.446
description $STC_MPLS$
encapsulation dot1Q 446
ip address 172.31.83.114 255.255.255.252
router bgp 100
bgp log-neighbor-changes
network 128.1.0.0 mask 255.255.248.0
network 172.18.0.0
network 172.19.0.0
neighbor 172.31.53.169 remote-as 65272
neighbor 172.31.92.42 remote-as 65272
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 84.235.x.x
ip route 128.1.0.0 255.255.248.0 GigabitEthernet0/1
ip route 172.17.0.0 255.255.0.0 172.31.92.41
ip route 172.18.0.0 255.255.0.0 GigabitEthernet0/1
ip route 172.19.0.0 255.255.0.0 GigabitEthernet0/1
ip route 172.31.53.168 255.255.255.252 172.31.83.113
ip route 172.31.92.40 255.255.255.252 172.31.83.113
control-plane
line con 0
logging synchronous
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
scheduler allocate 20000 1000
end
This router also carries a WAN connection along with the MPLS.
The route table for CORE_ROUTER:
Gateway of last resort is 84.235.x.x to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via 84.235.x.x
      20.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        20.20.20.0/24 is directly connected, Loopback0
L        20.20.20.20/32 is directly connected, Loopback0
      84.0.0.0/8 is variably subnetted, 4 subnets, 3 masks
C        84.235.x.x/28 is directly connected, GigabitEthernet0/2
L        84.235.x.x/32 is directly connected, GigabitEthernet0/2
C        84.235.x.x/30 is directly connected, GigabitEthernet0/0.2400
L        84.235.x.x/32 is directly connected, GigabitEthernet0/0.2400
      128.1.0.0/16 is variably subnetted, 3 subnets, 3 masks
S        128.1.0.0/21 is directly connected, GigabitEthernet0/1
C        128.1.0.96/29 is directly connected, GigabitEthernet0/1
L        128.1.0.100/32 is directly connected, GigabitEthernet0/1
S     172.17.0.0/16 [1/0] via 172.31.92.41
S     172.18.0.0/16 is directly connected, GigabitEthernet0/1
S     172.19.0.0/16 is directly connected, GigabitEthernet0/1
      172.31.0.0/16 is variably subnetted, 4 subnets, 2 masks
S        172.31.53.168/30 [1/0] via 172.31.83.113
C        172.31.83.112/30 is directly connected, FastEthernet0/0/0.446
L        172.31.83.114/32 is directly connected, FastEthernet0/0/0.446
S        172.31.92.40/30 [1/0] via 172.31.83.113
The BGP information on the same router:
CORE_Router#sh ip bgp
BGP table version is 4, local router ID is 20.20.20.20
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale, m multipath, b backup-path, x best-external, f RT-Filter
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
*> 128.1.0.0/21     0.0.0.0                  0         32768 i
*> 172.18.0.0       0.0.0.0                  0         32768 i
*> 172.19.0.0       0.0.0.0                  0         32768 i
on the CORE_ROUTER_QAT I have done the following configuration:
version 15.1
hostname CORE_ROUTER_QAT
boot-start-marker
boot-end-marker
enable secret 5 xxx
no aaa new-model
no ipv6 cef
ip source-route
ip cef
no ip domain lookup
crypto pki trustpoint TP-self-signed-437488504
subject-name cn=IOS-Self-Signed-Certificate-437488504
rsakeypair TP-self-signed-437488504
crypto pki certificate chain TP-self-signed-437488504
  xxx
        quit
license udi pid CISCO2911/K9 sn FCZ161370A1
no ip address
shutdown
ip address 172.31.92.42 255.255.255.252
duplex auto
speed auto
  no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.2
ip address 172.17.0.250 255.255.255.0
no ip address
shutdown
duplex auto
speed auto
router bgp 200
network 172.17.0.0
neighbor 172.31.83.113 remote-as 65272
ip http server
ip route 0.0.0.0 0.0.0.0 172.31.92.41
ip route 172.17.0.0 255.255.0.0 GigabitEthernet0/1.2
ip route 172.19.0.0 255.255.0.0 172.31.83.113
control-plane
line con 0
logging synchronous
login local
line aux 0
line 2
no exec
transport input all
stopbits 1
line vty 0 4
access-class 23 in
privilege level 15
login local
line vty 5 15
access-class 23 in
privilege level 15
login local
end
The route table and bgp information:
CORE_ROUTER_QAT#sh ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       + - replicated route, % - next hop override
Gateway of last resort is 172.31.92.41 to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via 172.31.92.41
      172.17.0.0/16 is variably subnetted, 3 subnets, 3 masks
S        172.17.0.0/16 is directly connected, GigabitEthernet0/1.2
C        172.17.0.0/24 is directly connected, GigabitEthernet0/1.2
L        172.17.0.250/32 is directly connected, GigabitEthernet0/1.2
      172.31.0.0/16 is variably subnetted, 2 subnets, 2 masks
C        172.31.92.40/30 is directly connected, GigabitEthernet0/0
L        172.31.92.42/32 is directly connected, GigabitEthernet0/0
CORE_ROUTER_QAT#sh ip bgp
BGP table version is 2, local router ID is 172.31.92.42
*> 172.17.0.0       0.0.0.0                  0         32768 i
Now the problems I am facing are like this
On CORE_ROUTER:
CORE_Router#ping 172.17.0.250
Sending 5, 100-byte ICMP Echos to 172.17.0.250, timeout is 2 seconds:
U.U.U
Success rate is 0 percent (0/5)
CORE_Router#traceroute 172.17.0.250
Tracing the route to 172.17.0.250
VRF info: (vrf in name/id, vrf out name/id)
  1 172.31.83.113 0 msec 0 msec 0 msec
  2 172.31.83.113 !H  *  !H
CORE_Router#ping 172.31.92.42
Sending 5, 100-byte ICMP Echos to 172.31.92.42, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 4/4/4 ms
on CORE_ROUTER_QAT:
CORE_ROUTER_QAT#ping 128.1.0.100
Sending 5, 100-byte ICMP Echos to 128.1.0.100, timeout is 2 seconds:
U.U.U
CORE_ROUTER_QAT#traceroute 128.1.0.100
Tracing the route to 128.1.0.100
  1 172.31.92.41 4 msec 4 msec 0 msec
  2 172.31.92.41 !H  *  !H
CORE_ROUTER_QAT#ping 172.31.83.114
Sending 5, 100-byte ICMP Echos to 172.31.83.114, timeout is 2 seconds:
Other than this I also face an Issue with CORE_ROUTER_QAT communicating with its local VLANS (I guess it might be due to the Alcatel at that site):
CORE_ROUTER_QAT#ping 172.17.0.254
Sending 5, 100-byte ICMP Echos to 172.17.0.254, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
CORE_ROUTER_QAT#traceroute 172.17.0.254
Tracing the route to 172.17.0.254
  1 172.17.0.254 4 msec 0 msec 4 msec
CORE_ROUTER_QAT#ping 172.17.6.10
Sending 5, 100-byte ICMP Echos to 172.17.6.10, timeout is 2 seconds:
CORE_ROUTER_QAT#traceroute 172.17.6.10
Tracing the route to 172.17.6.10
  1  *  *  *
  2  *  *  *
  3  *  *  *
  4  *  *  *
  5  *  *  *
  6  *  *  *
  7  *  *  *
  8  *  *  *
  9  *  *  *
10  *  *  *
11  *  *  *
12  *  *  *
13  *  *  *
14  *  *  *
15  *  *  *
16  *  *  *
17  *  *  *
18  *  *  *
19  *  *  *
20  *  *  *
21  *  *  *
22  *  *  *
23  *  *  *
24  *  *  *
25  *  *  *
26  *  *  *
27  *  *  *
28  *  *  *
29  *  *  *
30  *  *  *
I hope someone will be able to help me out with this issue.
Hall of Fame Super Silver
Hello Jobin,
you are dealing with eBGP multihop sessions on the first router, by default eBGP sessions use TTL=1 and a command is needed to setup the eBGP session in this case
you can check that eBGP sessions are not established with
show ip bgp sum
router bgp 100
neighbor x.x.x.x ebgp-multihop 255
neighbor y.y.y.y ebgp-multihop 255
repeat show ip bgp sum after the state of the BGP sessions should change to established
You may need to do the same on the other site
Hope to help
Giuseppe
Have a few doubts regarding this. By using the multihop should I be doing like this
router bgp 100
neighbor 172.31.92.41 ebgp-multihop 255
neighbor 172.31.53.169 ebgp-multihop 255
on the first router and similarly on the second router, where these IP's are the MPLS IP's or should I be using the IP for the remote site network ?
Re: Unable to ping remote LAN from PE
Hello Jobin,
it is exactly what I was meaning the command is an additional command that refers to the eBGP neighbors locally defined on the box
the resulting configuration on first device will be:
router bgp 100
neighbor 172.31.92.42 ebgp-multihop 255
do in a similar way on the other site if needed
you can check the state of BGP sessions with
show ip bgp summary
Hope to help
Giuseppe
Hi Giuseppe,
Did lik you had suggested however there are no changes in the bgp summary table.
hi
1. simple way to do it is gre tunnel from core_router to core_router_qat
2. another way is ipsec tunnel from f0/0/0.446 core_router to g0/0 core_router_qat
3. bgp inside mpls cloud
4. there are of course many ather ways to do it
I would like to configure the best possible method, Wouldn't bgp inside mpls cloud be better ? Considering that other sites to be added along to this which would be better ?
A few change to teh initial layout that I failed to mention.
The core switches on both the sides do not carry any bgp protocol, shoudl these switches also be enabled with the bgp ?
version 15.1
boot-start-marker
boot-end-marker
enable secret 5 xxx
no aaa new-model
no ipv6 cef
ip source-route
ip cef
no ip domain lookup
  xxx
        quit
no ip address
shutdown
duplex auto
speed auto
  no ip address
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
router bgp 200
network 172.17.0.0
ip http server
control-plane
line con 0
logging synchronous
login local
line aux 0
line 2
no exec
transport input all
stopbits 1
line vty 0 4
access-class 23 in
privilege level 15
login local
line vty 5 15
access-class 23 in
privilege level 15
login local
end
Even though there is a route to 172.19.0.0 mentioned in the router, why such i snot being displayed in  my routing table ?
After a few additions to configuration, ebg-multihop and gre tunnel, still there seems to be know reply from remote lan.
version 15.1
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip source-route
ip cef
no ip domain lookup
xxxxxx
        quit
interface Loopback0
ip address 20.20.20.20 255.255.255.255
interface Tunnel12
tunnel source FastEthernet0/0/0.446
tunnel destination 172.31.92.41
no ip address
shutdown
no ip address
duplex auto
speed auto
ip nat outside
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
no ip address
duplex auto
speed auto
router bgp 100
network 172.18.0.0
network 172.19.0.0
redistribute connected
neighbor 172.31.92.41 remote-as 65272
ip http server
control-plane
line con 0
logging synchronous
login local
line aux 0
line 2
no exec
transport input all
stopbits 1
line vty 0 4
access-class 23 in
privilege level 15
login local
line vty 5 15
access-class 23 in
privilege level 15
login local
end
version 15.1
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip source-route
ip cef
no ip domain lookup
  xxxxxxxx
        quit
interface Loopback0
ip address 20.20.20.21 255.255.255.255
interface Tunnel12
ip address 192.168.1.2 255.255.255.0
tunnel source GigabitEthernet0/0
tunnel destination 172.31.83.113
no ip address
shutdown
duplex auto
speed auto
no ip address
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
router bgp 200
network 172.17.0.0
neighbor 172.31.83.113 ebgp-multihop 255
ip http server
ip route 172.19.0.0 255.255.0.0 Tunnel12
control-plane
line con 0
logging synchronous
login local
line aux 0
line 2
no exec
transport input all
stopbits 1
line vty 0 4
access-class 23 in
privilege level 15
login local
line vty 5 15
access-class 23 in
privilege level 15
login local
end
The tables display the following details now, though briefly it did show the bpg as active it continues to show as idle.
CORE_Router#sh ip route
      20.0.0.0/32 is subnetted, 1 subnets
C        20.20.20.20 is directly connected, Loopback0
      192.168.1.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.1.0/24 is directly connected, Tunnel12
L        192.168.1.1/32 is directly connected, Tunnel12
CORE_Router#sh ip bgp sum
BGP router identifier 20.20.20.20, local AS number 100
BGP table version is 16, main routing table version 16
9 network entries using 1224 bytes of memory
9 path entries using 504 bytes of memory
2/2 BGP path/bestpath attribute entries using 256 bytes of memory
0 BGP route-map cache entries using 0 bytes of memory
0 BGP filter-list cache entries using 0 bytes of memory
BGP using 1984 total bytes of memory
BGP activity 9/0 prefixes, 9/0 paths, scan interval 60 secs
Neighbor        V           AS MsgRcvd MsgSent   TblVer  InQ OutQ Up/Down  State/PfxRcd
172.31.53.169   4        65272       0       0        1    0    0 never    Idle
172.31.92.41    4        65272       0       0        1    0    0 never    Idle
C        20.20.20.21 is directly connected, Loopback0
      172.17.0.0/16 is variably subnetted, 2 subnets, 2 masks
S     172.19.0.0/16 is directly connected, Tunnel12
L        192.168.1.2/32 is directly connected, Tunnel12
CORE_ROUTER_QAT#sh ip bgp sum
BGP router identifier 20.20.20.21, local AS number 200
BGP table version is 1, main routing table version 1
172.31.83.113   4        65272       0       0        1    0    0 never    Idle
However, the tunnel interfaces in no way seems to communicate each other too, with no trace when using traceroute function
CORE_Router#ping 192.168.1.1
Sending 5, 100-byte ICMP Echos to 192.168.1.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
CORE_Router#ping 192.168.1.2
Sending 5, 100-byte ICMP Echos to 192.168.1.2, timeout is 2 seconds:
CORE_ROUTER_QAT#ping 192.168.1.2
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
CORE_ROUTER_QAT#ping 192.168.1.1
This has me all lost now, any suggestions ?
Hello Jobin,
looking again at your second network diagram I think I have found the root cause:
the expected eBGP configuration is that each CE node has an eBGP session with the locally connected PE node, you don't need to attempt to create BGP sessions with the CE or the PE at the remote site. This job is performed by SP network using their BGP signalling infrastructure.
L3 MPLS VPN uses a peer model for signaling that means that you just care of peering with local PE node in each site and SP does all the job for you.
So on router named core_router you need an eBGP session with local PE node
CORE_router:
router bgp 100
and on the other CE node:
CORE_ROUTER_QAT
router bgp 100
You can delete all the other BGP sessions as they are not needed and even not correct in theory for this service model.
Hope to help
Giuseppe
Hi Giuseppe, I did changes to the bgp configurtaion on both the routers. The sh ip bgp summary gave the following result
BGP table version is 139, main routing table version 139
8 network entries using 1088 bytes of memory
8 path entries using 448 bytes of memory
BGP using 1792 total bytes of memory
BGP activity 25/17 prefixes, 86/78 paths, scan interval 60 secs
BGP table version is 364, main routing table version 364
3 network entries using 408 bytes of memory
3 path entries using 168 bytes of memory
1/1 BGP path/bestpath attribute entries using 128 bytes of memory
BGP using 704 total bytes of memory
BGP activity 46/43 prefixes, 199/196 paths, scan interval 60 secs
/PfxRcd
I tried to telnet port 179 on both the router at the result was connection refused.
CORE_Router#telnet 172.31.92.42 179 /source-interface fastEthernet 0/0/0.446
Trying 172.31.92.42, 179 ...
% Connection refused by remote host
CORE_ROUTER_QAT#telnet 172.31.83.114 179
Trying 172.31.83.114, 179 ...
CORE_ROUTER_QAT#$31.83.114 179 /source-interface gigabitEthernet 0/0
Later I added changes to bgp on both the switches adding the neigbhor CE bgp.
on CORE_ROUTER:
router bgp 100
bgp graceful-restart restart-time 120
bgp graceful-restart stalepath-time 360
network 172.18.0.0
network 172.19.0.0
neighbor 172.31.92.42 remote-as 200
on CORE_ROUTER_QAT:
router bgp 200
network 172.17.0.0
neighbor 172.31.83.114 remote-as 100
neighbor 172.31.83.114 ebgp-multihop 255
The bgp summary showed active connections but the communication to CE interface is awkward:
BGP table version is 142, local router ID is 20.20.20.20
*> 20.20.20.20/32   0.0.0.0                  0         32768 ?
*> 20.20.20.21/32   172.31.92.42             0             0 200 ?
*> 84.235.x.x/28 0.0.0.0                  0         32768 ?
*> 84.235.x.x/30   0.0.0.0                  0         32768 ?
*> 128.1.0.96/29    0.0.0.0                  0         32768 ?
*> 172.17.0.0/24    172.31.92.42             0             0 200 ?
*> 172.31.83.112/30 0.0.0.0                  0         32768 ?
r> 172.31.92.40/30  172.31.92.42             0             0 200 ?
BGP table version is 142, main routing table version 142
11 network entries using 1496 bytes of memory
11 path entries using 616 bytes of memory
3/3 BGP path/bestpath attribute entries using 384 bytes of memory
1 BGP AS-PATH entries using 24 bytes of memory
BGP using 2520 total bytes of memory
BGP activity 28/17 prefixes, 89/78 paths, scan interval 60 secs
172.31.92.42    4          200       5       6      139    0    0 00:00:25        3
      20.0.0.0/32 is subnetted, 2 subnets
B        20.20.20.21 [20/0] via 172.31.92.42, 00:00:30
      172.17.0.0/24 is subnetted, 1 subnets
B        172.17.0.0 [20/0] via 172.31.92.42, 00:00:30
BGP table version is 379, local router ID is 20.20.20.21
l, f RT-Filter
*  20.20.20.20/32   172.31.83.114            0             0 100 ?
*> 20.20.20.21/32   0.0.0.0                  0         32768 ?
*  84.235.x.x/28 172.31.83.114            0             0 100 ?
*  84.235.x.x/30   172.31.83.114            0             0 100 ?
*  128.1.0.0/21     172.31.83.114            0             0 100 i
*  128.1.0.96/29    172.31.83.114            0             0 100 ?
*> 172.17.0.0/24    0.0.0.0                  0         32768 ?
*  172.18.0.0       172.31.83.114            0             0 100 i
*  172.19.0.0       172.31.83.114            0             0 100 i
*> 172.31.83.112/30 172.31.83.114            0             0 100 ?
*> 172.31.92.40/30  0.0.0.0                  0         32768 ?
BGP table version is 379, main routing table version 379
3/2 BGP path/bestpath attribute entries using 384 bytes of memory
BGP activity 54/43 prefixes, 207/196 paths, scan interval 60 secs
/PfxRcd
172.31.83.114   4          100       8       7        1    0    0 00:01:51
  8
      172.31.0.0/16 is variably subnetted, 3 subnets, 2 masks
B        172.31.83.112/30 [20/0] via 172.31.83.114, 00:01:59
CORE_Router#ping 172.31.92.41
Sending 5, 100-byte ICMP Echos to 172.31.92.41, timeout is 2 seconds:
CORE_Router#traceroute 172.31.92.42
Tracing the route to 172.31.92.42
  2  *  *  *
  3  *  *  *
  4  *  *  *
  5  *  *  *
  6  *  *  *
  7  *  *  *
  8  *  *  *
  9  *  *  *
10  *  *  *
11  *  *  *
12  *  *
    172.31.92.42 8 msec
  1 172.31.83.113 24 msec 4 msec 52 msec
  2  *  *  *
  3  *  *  *
  4  *  *  *
  5  *  *  *
  6  *  *  *
  7  *  *  *
  8  *  *  *
  9  *  *  *
10  *  *  *
11  *  *
Success rate is 60 percent (3/5), round-trip min/avg/max = 1/3/4 ms
U.U.
Success rate is 0 percent (0/4)
CORE_ROUTER_QAT#ping 172.31.83.113
Sending 5, 100-byte ICMP Echos to 172.31.83.113, timeout is 2 seconds:
Success rate is 40 percent (2/5), round-trip min/avg/max = 4/4/4 ms
CORE_ROUTER_QAT#traceroute 172.31.83.113
Tracing the route to 172.31.83.113
  1  *  *  *
  2  *
Success rate is 100 percent (5/5), round-trip min/avg/max = 4/4/8 ms
Hello Jobin,
contact the MPLS service provider it looks like that they haven't configured their side the PE-CE eBGP sessions.
The Service Provider has the configuration to route the PE-CE links and this allows you to ping the remote PE but you cannot ping the remote CE as the PE-CE eBGP sessions are not established.
The eBGP session with the remote CE is not usual in this kind of setup as I have noted previously it may be able to go up but it doesn't solve your issues you need to contact the MPLS SP tech support.
Hope to help
Giuseppe
1234
