Webcast-Catalyst9k
Unable to telnet
hi,
i  have a cisco  router and has a single public IP configured on one of  giga port .And have a server on LAN  whose  IP  i have static nat to  public IP on port 3389 for remote access to server which is  successful.But i am not able to telnet router on public IP configured .
1 ACCEPTED SOLUTION
Purple
Unable to telnet
no access-list 101
access-list 99 permit 192.168.60.0 0.0.0.255
access-list 99 permit 192.168.55.0 0.0.0.255
no ip nat inside source list 101 interface GigabitEthernet0/1
ip nat inside source list 99  interface GigabitEthernet0/1
Regards.
Alain
Purple
Unable to telnet
Do you want to telnet from outside to this server ? then you must have a static PAT for port 23
Have you got ACLs or a firewall config on the router ?
I think it's best you post your config.
Regards.
Alain.
Re: Unable to telnet
hi,
find the config
sh run
Building configuration...
Current configuration : 3905 bytes
! Last configuration change at 12:07:20 UTC Mon Feb 20 2012
version 15.0
service password-encryption
hostname xxxxx
boot-start-marker
boot-end-marker
enable secret 5 $1$C7ve$1g11FJeUyUmgTBMkg8.3A/
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 192.168.55.1 192.168.55.10
ip dhcp excluded-address 192.168.60.1 192.168.60.10
ip dhcp pool VOICE
network 192.168.55.0 255.255.255.0
default-router 192.168.55.1
option 150 ip 192.168.55.1
dns-server 113.193.1.60 113.193.1.14
ip dhcp pool DATA
network 192.168.60.0 255.255.255.0
default-router 192.168.60.1
option 150 ip 192.168.60.1
ip name-server 113.193.1.60
ip name-server 113.193.1.14
redundancy
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.55
encapsulation dot1Q 55
ip address 192.168.55.1 255.255.255.0
ip nat inside
ip virtual-reassembly
interface GigabitEthernet0/0.60
encapsulation dot1Q 60
ip address 192.168.60.1 255.255.255.0
ip nat inside
ip address 113.x.x.157 255.255.255.254
ip nat outside
duplex auto
speed auto
ip default-gateway 113.x.x.156
ip forward-protocol nd
ip http server
ip http secure-server
ip nat inside source list 101 interface GigabitEthernet0/1 overload
ip nat inside source static tcp 192.168.60.9 3389 113.x.x.157 3389 extendabl (its server LAN IP-192.168.60.9)
ip route 0.0.0.0 0.0.0.0 113.x.x.156
access-list 101 permit ip any any
tftp-server flash:apps42.9-2-3TH1-9.sbn
tftp-server flash:cnu42.9-2-3TH1-9.sbn
tftp-server flash:cvm42sccp.9-2-3TH1-9.sbn
tftp-server flash:dsp42.9-2-3TH1-9.sbn
tftp-server flash:jar42sccp.9-2-3TH1-9.sbn
tftp-server flash:SCCP42.9-2-3S.loads
tftp-server flash:term42.default.loads
tftp-server flash:term62.default.loads
control-plane
line con 0
password 7 04481F0F0126495C0017011E13
login
line aux 0
line vty 0 4
password 7 0215105205010A3345400D1004
login
scheduler allocate 20000 1000
end
Bhavesh
hi,
i am not able to telnet router from outside.
Bhavesh
Purple
Unable to telnet
no access-list 101
Regards.
Alain
hi Alain,
as u replied standard access list to be configured,but will i be able to access sever remotely .
Purple
Unable to telnet
you'll be able to start a remote desktop session remotely to the server but not telnet to it.
Is this what you want ?
Can you telnet to the router from outside now ?
Regards.
Alain
347
