Unusual behavior on 2nd port of 2 port MC T3 card.
I am having an odd problem. I have a 2 port MC-T2 card installed in a 7206VXR in slot 5. Port 5/0 is behaving as expected. We are bring up a new Channelizes DS3 on port 5/1 and I am getting behavior that generated the output below when I issue the "show controller T3 5/1" command. The controller shows DOWN while the T1 channels on the controller show UP/UP. any thoughts?
T3 5/1 is down. Hardware is 2CT3 single wide port adapter
CT3 H/W Version : 0.2.2, CT3 ROM Version : 1.0, CT3 F/W Version : 2.5.1
FREEDM version: 1, reset 0 resurrect 0
Applique type is Channelized T3
No alarms detected.
FEAC code received: No code is being received
Framing is M23, Line Code is B3ZS, Clock Source is Line
Rx-error throttling on T1's ENABLED
Rx throttle total 0, equipment customer loopback
Data in current interval (2 seconds elapsed):
0 Line Code Violations, 0 P-bit Coding Violation
0 C-bit Coding Violation, 0 P-bit Err Secs
0 P-bit Severely Err Secs, 0 Severely Err Framing Secs
0 Unavailable Secs, 0 Line Errored Secs
0 C-bit Errored Secs, 0 C-bit Severely Errored Secs
T1 1 is up
timeslots: 1-24
FDL per AT&T 54016 spec.
No alarms detected.
Framing is ESF, Clock Source is Internal
Data in current interval (82 seconds elapsed):
0 Line Code Violations, 581 Path Code Violations
0 Slip Secs, 3 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
3 Errored Secs, 0 Bursty Err Secs, 3 Severely Err Secs
0 Unavail Secs, 0 Stuffed Secs
T1 2 is up
timeslots: 1-24
No alarms detected.
Data in current interval (83 seconds elapsed):
0 Slip Secs, 2 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
2 Errored Secs, 0 Bursty Err Secs, 2 Severely Err Secs
Thanks..
Hall of Fame Super Gold
Re: Unusual behavior on 2nd port of 2 port MC T3 card.
Why you blame the port?
Do you have evidence that the circuit is working on a different port ?
I am scheduling to move the circuit to another T3 port, that is currently working, to see if the behavior follows. Thanks for the input.
Hall of Fame Super Silver
Hello Paul,
I see
this may be related to the fact second T3 is considered down
Hope to help
Giuseppe
That in itself is normal, no loop code is being received.
All appears normal, but maybe telco has not completed their mux configuration.
129
