Update for 2007 DST for 4006 switch and 3640 router
hey guys,
i m using 4006s and 3640s.
as US government is announcing new DST starting 2007, would we have to update the IOS for the above mentioned devices to reflect the new DST?
Is there any command that can manually fix it?
Re: Update for 2007 DST for 4006 switch and 3640 router
There is a command to adjust the Day Light saving time on the switch.
Check this link:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/8_1/config/ntp.htm#1020108
This should help you.
-amit singh
Yes,
I know about that command.
Just wondering, will Cisco release an IOS update or a patch to fix that as well.
Nops, I dont think so. But if there is any I will keep you posted here on this.
-amit singh
99
