Upgradation of flash
While upgrading Flash on router it goes into rommon mode. How can I back into router mode?
I use command confreg 0x2101 and reset but int again goes into rommon mode.
Please help.
Re: Upgradation of flash
Set the configuration register to 0x2102. Set the boot path from the rommon using " BOOT:=bootflash: and manually boot the router. Once it is up save the running config.
let us know how did it go.
http://www.cisco.com/en/US/products/hw/routers/ps274/products_tech_note09186a008009429f.shtml
It saying that Input redirection is not supported at this level.
Hai,
Are you sure that ios is transferd sucfly to Flash ..?? if so ...
...when are you getting this error ???
rommman>confreg 0x2102
romman> reset
ujil
Hi Ujil,
When I set the configuration register to 0x2102. And then set the boot path from the rommon using " BOOT:=bootflash:,
it gives that error.
And how I know that ios is transferd sucfly to Flash?
When I put command dev it shows flash but I put command dir flash it shows error that bad device name.
hai,
I suspect ios is not properly tranfrd ,,,,can u try uploading the ios once again ...via console and see the status ....
Guys correct me if i am wrong
ujil
rommon mode is a bit more sensitive than the IOS prompt. try using "dir FLASH:" (without quotes). Redirect implies you actually use "" when using boot. Is this assumption correct?
When I put the command dir flash, it shows error that bad device name.
I think router's flash is corrupted.
Pleae educate me on this issue.
Hai,
Try to transfer the ios via console cable.(Which series router u are using) ...
in rommoniter mode you can use the command xmodem
rommen>xmodem
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a008015bfac.shtml
ujil
Thanks. It's done by downloading a software image via TFTP using the tftpdnld ROMMON ommand.
hai,
thanks for the update .....
ujil
178
