upgrade IOS
support.golan
hello my ios version is:
attached
i need version support VPN how can i upgrade it
can you send me details please
golan
abdussamedpkpk
Dear
Check the flash by dir command, if you have enough space in it, copy the ios file. Otherwise delete the current file and copy. You can copy through tftp. If you don't know the procedure to use tftp, just send reply me to my emai.
Then you can change the boot sysytem file with command "boot system flash {file-name}". Then reload the router.
please explain me the procedure
Hello Golan,
You need an IOS with advanced security feature (see below example).  You also need a CCO account to be able to download the IOS
c1841-advsecurityk9-mz.124-11.XW10.bin
Reza
Leo Laohoo
Cisco IOS Software Upgrade Procedure
http://www.cisco.com/en/US/products/hw/routers/ps380/products_tech_note09186a0080117772.shtml
How to Download a Software Image to a Cisco 2600 via TFTP Using the tftpdnld ROMMON Command
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a008015bf9e.shtml
If my post is helpful and or useful, please don't hesitate to rate.  Thank you.
