Uplink port changes to orange after 12-36 hours switch stops responding
If I unplug the cable from the uplink port and plug it back it, the switch starts responding again.
What could be causing this?
  • WAN Routing and Switching
Re: Uplink port changes to orange after 12-36 hours switch stops
There are some features and bugs, which could cause this. Can you provide the respective switch port configurations?
Regards, Martin
Here they are:
The log on the switch in cabinet #1 is saying:
8w2d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to down
8w2d: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to down
8w2d: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to up
8w2d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to up
Log on the switch in cabinet #2 says something similar.
1d11h: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/2, changed state to down
1d11h: %LINK-3-UPDOWN: Interface GigabitEthernet0/2, changed state to down
1d11h: %LINK-3-UPDOWN: Interface GigabitEthernet0/2, changed state to up
1d11h: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/2, changed state to up
Both ports are set at 1000MBPS full duplex
cabinet #1
GigabitEthernet0/1 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 0012.43a2.1719 (bia 0012.43a2.1719)
MTU 1500 bytes, BW 1000000 Kbit, DLY 1000 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is RJ45
input flow-control is off, output flow-control is off
Last input 00:00:19, output 00:00:01, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 2928000 bits/sec, 354 packets/sec
5 minute output rate 219000 bits/sec, 247 packets/sec
1837014603 packets input, 4093253980 bytes, 0 no buffer
Received 4121860 broadcasts (0 multicast)
9228 input errors, 9210 CRC, 0 frame, 0 overrun, 20795 ignored
0 watchdog, 269265 multicast, 0 pause input
1565825770 packets output, 1450541785 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
cabinet #2
GigabitEthernet0/2 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 0015.63bb.6d1a (bia 0015.63bb.6d1a)
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Last input 00:00:00, output 00:00:06, output hang never
5 minute input rate 245000 bits/sec, 281 packets/sec
5 minute output rate 3324000 bits/sec, 398 packets/sec
21675498 packets input, 23077065 bytes, 0 no buffer
Received 655386 broadcasts (0 multicast)
0 runts, 6 giants, 0 throttles
8391 input errors, 8385 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 394750 multicast, 0 pause input
28663675 packets output, 2594052940 bytes, 0 underruns
The information presented does not allow to finally conclude a certain reason. Could you provide the interface configurations?
Have you checked cabling as well?
Regards, Martin
>>What command do I type to get the output you are looking for?
>>Yes, I even tried a new cable.
"show run interface GigabitEthernet0/1" with the proper interface numbers.
Thanks!
On the first switch its:
Building configuration...
Current configuration : 49 bytes
duplex full
end
on the second switch its:
show run interface GigabitEthernet0/2
Current configuration : 36 bytes
end
Are they suppose to be the same bytes?
No, the number of bytes is just indicating how much data is used for storing this particular part of the configuration.
As the interfaces are in default configuration, I cannot see any reason for the observed behaviour.
Sorry not to be more helpful.
Regards, Martin
224
