[Urgent] Problem of 7600 ES20 card
CSCO11777723
hello,
I meet a very strange problem about the cisco 7600 ES20 line card.
I use:
- Sup 720-3BXL(MSFC3)
- ES20(20x1GE) 3CXL
Services:
-EVC 400(production)
-SVI terminate the EVC links
- MPLS VPN(20-30)
The problem we met was that the ES20 crash very frequantly.
*Jun  7 01:25:49.127 CET: %DIAG-SP-6-TEST_RUNNING: Module 6: Running TestFabricSnakeForward{ID=24} ...
7k1.edge.nc#
*Jun  7 01:25:54.383 CET: %DIAG-SP-3-TEST_FAIL: Module 6: TestFabricSnakeForward{ID=24} has failed. Error code = 0x1 (DIAG_FAILURE)
7k1.edge.nc#
*Jun  7 01:25:54.663 CET: %C6KPWR-SP-4-DISABLED: power to module in slot 2 set off (Fabric channel errors)
*Jun  7 01:38:41.939 CET: %ICC-5-HUGE_BUFFER: Class [RPC    ] with Request id 0 requested a huge buffer of Size 65016.
*Jun  7 01:22:17.699 CET: %ESM20-DFC2-3-UNEXPECTED_GLOBAL_INT: Unexpected Global Interrupt: Xchip_1 Error
Please who know meet the same problem or have the solution?
Thanks a lot
Giuseppe Larosa
Hello Vincent,
try to reseat the module because it shows fabric errors
If this does not work, if you have a free slot you can try to insert it in another slot.
If error keeps occurring is high time to open an RMA with TAC
Hope to help
Giuseppe
Hi Giuseppe,
Thanks for your reply.
The card reboots itself several seconds after and then comes back after 5 minutes. We tried to change the slot, change the card with a spare one. Put a new chassis to load balance but no luck.
May 11 09:36:47.108 CET: %INTR_MGR-DFC1-3-INTR: Queueing Engine (Blackwater) [0]: EPMC Correctable ECC error
May 11 09:38:52.449 CET: %INTR_MGR-DFC1-3-INTR: Queueing Engine (Blackwater) [0]: EPMC Uncorrectable ECC error
May 11 09:38:52.449 CET: %ESM20-DFC1-3-UNEXPECTED_GLOBAL_INT: Unexpected Global Interrupt: Blackwater_0/Icewater_0 Error
May 11 09:38:52.453 CET: %DFCWLC-DFC1-2-UNRECOVERABLE_FAILURE: DFC WAN Line Card Unrecoverable Failure for Device: Queueing Engine (Blackwater)
%Software-forced reload
Strangely, the problem seams to append periodically. When the chassis is not rebooted we can see that the card crash precisely 10 or 40 or 90 or 120 minutes :
#dir dfc#1-disk0:
Directory of dfc#1-disk0:/
   11  -rw-      812366  May 11 2012 11:23:50 +02:00  crashinfo_20120511-092351-CET
   12  -rw-      802602  May 11 2012 11:38:52 +02:00  crashinfo_20120511-093852-CET
   13  -rw-      797126  May 14 2012 17:00:02 +02:00  crashinfo_20120514-150002-CET
   14  -rw-      953210  May 16 2012 16:28:32 +02:00  crashinfo_20120516-162827-CET
   15  -rw-      955152  May 16 2012 17:39:34 +02:00  crashinfo_20120516-173931-CET
   16  -rw-      957863  May 30 2012 18:54:46 +02:00  crashinfo_20120530-185442-CET
   17  -rw-      943013  May 30 2012 19:04:46 +02:00  crashinfo_20120530-190442-CET
   18  -rw-      973486  May 30 2012 19:20:28 +02:00  crashinfo_20120530-192024-CET
   19  -rw-      948453  May 30 2012 19:44:46 +02:00  crashinfo_20120530-194442-CET
   20  -rw-      958010   Jun 6 2012 12:59:42 +02:00  crashinfo_20120606-125938-CET
   21  -rw-      951897   Jun 6 2012 14:59:42 +02:00  crashinfo_20120606-145939-CET
   22  -rw-      943127   Jun 6 2012 16:29:38 +02:00  crashinfo_20120606-162939-CET
Everything works beautifully for months with the exact same ios and configuration. Upgrading ios didn't solve the problem.
Vincent
Hello Vincent,
open a TAC service request to have them to analyze your issue.
It is quite complex to troubleshoot and you have done all the reasonable attempts to check if it is an HW problem and it looks like it isn't, or at least not in the affected linecard as you have changed slot you have changed the linecard.
Hope to help
Giuseppe
