URGENT - problem with Cisco 876 and ADSL over ISDN
I'm having problems with a Cisco 876 router (ADSL over ISDN Anex B, 1024/256 Kbp/s). I'm try to configure ADSL connection with public IP address from ISP. My configuration is bad, not work's. If you have any good suggestion write to me. I not assured how to configure ATM0, Dialer0, NAT and others interfaces.
Re: URGENT - problem with Cisco 876 and ADSL over ISDN
ISP support LLC, GDMT ADSL (ITU G.992.1/G.992.2) encapsulation, pvc 8/35. ISP have Ericsson DSLAM equipment. If you have same configuration post it!!! I'm so tired and not have solutions for this problems!
Hall of Fame Super Gold
First of all check "show isdn status" to see if the link goes up.
Then specify if your ISP is using PPPoE, bridged 1483 or what else, and post your configuration.
This is my config:
Current configuration : 4050 bytes
version 12.4
service password-encryption
hostname xxxx
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 5 xxxx
no aaa new-model
resource policy
ip cef
no ip domain lookup
ip name-server xxx.xxx.xxx.xxx
username xxxx privilege 15 password 7 xxxxxxx
interface Loopback0
no ip address
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
description ADSL 1024/256
ip address xxx.xxx.xxx.xxx 255.255.255.0 (Public, static IP from ISP)
ip access-group 100 in
ip nat outside
ip virtual-reassembly
no snmp trap link-status
pvc 8/35
encapsulation aal5snap
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
ip address xxx.xxx.xxx.xxx 255.255.255.0 (Private IP)
ip nat inside
ip tcp adjust-mss 1412
ip route 0.0.0.0 0.0.0.0 xxx.xxx.xxx.xxx (Gateway from ISP)
no ip http server
ip http authentication local
ip http secure-server
ip nat inside source list 100 interface Vlan1 overload
ip nat inside source static xxx.xxx.xxx.xxx (Private IP) xxx.xxx.xxx.xxx (Public, static IP from ISP)
access-list 100 permit ip any any
no cdp run
control-plane
line con 0
no modem enable
line aux 0
access-class 23 in
privilege level 15
login local
transport input telnet ssh
line vty 0 4
login
line vty 5 15
access-class 23 in
privilege level 15
login local
scheduler max-task-time 5000
webvpn context Default_context
ssl authenticate verify all
no inservice
end
This is status interfaces:
xxxx#sh ip int brief
FastEthernet0 unassigned YES unset up up
FastEthernet1 unassigned YES unset up down
FastEthernet2 unassigned YES unset up down
FastEthernet3 unassigned YES unset down down
BRI0 unassigned YES NVRAM administratively down down
BRI0:1 unassigned YES unset administratively down down
BRI0:2 unassigned YES unset administratively down down
ATM0 unassigned YES NVRAM up up
ATM0.1 xxx.xxx.xxx.xxx (Public ISP from ISP) YES NVRAM up up
Vlan1 xxx.xxx.xxx.xxx (Private IP) YES NVRAM up up
Loopback0 unassigned YES NVRAM up up
NVI0 unassigned NO unset up up
As mentoned above:
Then specify if your ISP is using PPPoE, bridged 1483 or what else.
273
