02-22-2010 10:34 PM - edited 03-04-2019 07:35 AM
Hello
I Have to sites connected the head office via 2 MB DSL as a Link the Topology is DMVPN,but we r missing the redundancy for that,so now what kind of redundancy should i use and Implement here?
02-22-2010 11:55 PM
Hello Alsayed,
you have not provided details about your current scenario.
Redundancy can be implemented in different ways, including the use of a second DMVPN cloud pointing to another hub router for example.
Or it can be a form of Dial on demand routing over ISDN or over UMTS or so on.
the basic requirement should be a separate interface to be used to connect to another provider.
Hope to help
Giuseppe
02-23-2010 12:09 AM
Hi Giuseppe its been long time
Do you have any deployment or design scenario similar to my requirment?
Thanks a lot
