USB console port on 1900 series
TRACY HARTMANN
I would like to try and use the USB port on the router instead of the RJ45 port.  What cable do I need for that?  Do I need to configure anything differently on the router?
Leo Laohoo
The cables are the usual USB to USB-Mini which you can buy cheaply at any electronics shop.
You will need to install the driver and the driver can be found HERE.
miaozhixu
The cable is USB to USB-Mini B type. It needs driver on MS Windows, as no driver needed on Mac OSX.
