Use both WAN link parrarelly
i got 2 cisco 2811 router. I have one leased line and one radio bandwidth both are of the 2 mbps. I want to use both of them pararelly to provide 4mbps throughput. More i'm using default route as internet access is done on
other side from this link.
Plz advice me which technology is better for me.
thks,
Re: Use both WAN link parrarelly
If you are connecting these links on both the routers then you can think off going for GLBP which will help to loadbalance in addition to redundancy between the links as well as on the hardware levels..
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a008042fb97.html
regds
Hi Sprem,
Actually is to use both link together to maximize the bandwitdh for the data transfer.
Any commands/technology can be used to do this?
thks,
rgds,
kenny
If they are both on the same router, you can get this done easily by using 2 default routes. Thes will load share the packets for you.
If on separate routers use GLBP
145
