username autocommand - no more works
paolo bevilacqua
12.4XJ, tried
username test nopassword telnet 10.30.4.5 /source vlan2
it lets me login in without password but autocommand is not executed.
Has anyone seen this also ?
9 Replies 9
ariela
Level 4
Level 4
please try this:
username test nopassword autocommand telnet 10.30.4.5 /source vlan2
Let me know
Andrea
Whoop's, that is what I have used. Mistyped copying the command above.
I need your specific release.
thanks
Andrea
12.4XJ as of today is only 12.4(11)XJ1 or XJ2.
Also tried with 12.4(11)T, same result.
Does it work for you ?
well,
I've you already tried with:
Andrea
Yes as it told you before ...
Without autocommand is command not valid!
Paolo,
I quickly tested your setup in my lab and it works fine. I don't know if there's a 'additional blank space' or 'space missing' in your autocommand syntax. Try removing the config and reentering it.
username test autocommand telnet 172.30.1.11 /source loopback123
R2#172.30.1.12
Trying 172.30.1.12 ... Open
User Access Verification
Username: test
Trying 172.30.1.11 ... Open
Password required, but none set
[Connection to 172.30.1.11 closed by foreign host]
[Connection to 172.30.1.12 closed by foreign host]
Sundar
Hi Sundar, thanks for trying. Which IOS on your test router ?
123-17a. It's a 2611.
Sundar
