Webcast-Catalyst9k
V WIC 1MFT G703 E1 CONTROLLER CARD
HI,
V WIC 1MFT G703 E1 CONTROLLER CARD,It will support 2mbps data in 1841 cisco?
KIndly confirm the config:
Config t
Controller E1 0/0/0
channel-group 0 unframed
Config t
int serial 0/0/0:0
bandwidth 2048
ip address x.x.x.x x.x.x.x
Kindly revert back
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: V WIC 1MFT G703 E1 CONTROLLER CARD
Another note, if you use "timeslots 1-31", you don't need the G.703 version of VWIC, but just the normal one, that is much less expensive.
The G.703 version is only needed when you absolutely need to support "unframed".
Since channel-group is set to 'unframed',It will definitely support 2 mbps speed.
Please rate ,if it is useful.
--Jaffer
HI,
VWIC IMFT G703 EI CONTROLLER CARD ,IT WILL SUPPORT DATA?
Bronze
I think you need to use timeslot 1-31 ,please see below command .
channel-group 0 timeslots 1-31
I hope this will help you out.
-Minu
There is a difference,
Channel-group 1 timeslots 1-31 is framed at 1.984 Mbps.
Channel-group 1 unframed, is 2.048 Mbps.
On an unframed circuit you can use both.
Of course all the vwic cards supports data.
487
