Community Member
V35 cables (CAB-V35MT, CAB-V35FC)
Is there anyway to have a V35 connectivity between equipments that is more than 32 feet distance?
Each Cisco CAB-SS-V35MT is only 10 feet long; with one end as IAD serial port, and the other end as V35.
Even if we interlink the each CAB-V35MT and each CAB-V35FC cables together, they can only achieve 20 feet distance, but it only ended up both ends with serial-serial (i.e IAD to IAD).
How are we going to connect the third one?? Please refer attached.
Silver
Re: V35 cables (CAB-V35MT, CAB-V35FC)
Please refer to this link for recommended cable lengths.
http://www.cisco.com/en/US/products/hw/switches/ps988/products_tech_note09186a0080093cee.shtml
You can insert a V.35 (Male/Female) extender cable in between to extend the length.
Hope it helps, rate if does,
Krisztian
Community Member
Hi Krisztian,
How does a V.35 (Male/Female) extender cable look like? Any reference?
Silver
Please refer to this link:
http://www.cablek.com/catalog/product_info.php?&products_id=3418
Krisztian
1092
