Community Member
vc unable to call outside
Hi all,
I am not able to call out side from my VC policom which is connected to my 2811 router with ip-sec bundle.where iam able to recieve calls from outside network(internet).Please help me in resolving this issue.Please find attm..
Satya.M
1 REPLY
Hall of Fame Super Silver
Re: vc unable to call outside
Hello Satya,
have you enabled any security feature on the WAN interface ?
I see some ACLs defined but they are not applied to fastethernet ports
where is connected the VC ?
You should provide some more details to get better help.
Edit:
I see that f0/0 is your external interface
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
so the VC has to be on f0/1
if you have public addresses NAT is not involved no ACLs are applied on the two interfaces (LAN and WAN) and so the router should not be a problem.
Hope to help
Giuseppe
107
