very urgent --GRE tunneling
very urgent -- will cisco GSR 12000 Series support GRE tunneling
Re: very urgent --GRE tunneling
hi,
will it support by default or i should insert some tunnel line card.
no cards should be nessary - try to configure:-
int tun0
encapsulation tunnel
see what happens?
i have my colleagues saying 12000 GSR doesnt support GRE Tunneling ? there are some limitations.is it so.
do anyone confgiured on GRE tunnel on GSR.
rgds/shiva
Bronze
Hi Shiva,
Yes, it needs a card to enable GRE tunneling.
It's there in the same document in prerequisites section.
Dedicated Line Card Required
In order for a GRE tunnel on a Cisco 12000 series Internet router to come up, a Cisco 1-port OC-48 POS line card (tunnel server card) must be installed.
Apart from this, there are no other limitations as far as I know.
Regards...
-Ashok.
With best regards... Ashok ----------- Pls kindly rate if helpful or answered your question.
hi ashok,
do you use GRE tunneling on your 12000 series router or you are sharing your knowledge expertise.
210
