Viewing websites through a cisco 857w
Hi, I seem to be having a problem with displaying web pages over our 857w router. The ADSL seems to be connecting OK and we can get a web page displayed on a PC if we type the ip address of the site into the address bar. so if I type www.google.com we get an DNS error message displayed on the browser, but if we type 64.233.183.99 the page displays perfectly.
We have been using a vigor 2600+ router which connect perfectly every time. Different dns server ip's have been used but we still get the same results.
What are we missing, I have attached the running config so any help would be greatly welcomed.
Re: Viewing websites through a cisco 857w
You need to specify the DNS server under the DHCP pool rather than in the ip name-server command. I think the ip name-server command is for use by the router itself, and is not passed out to the DHCP clients.
What you need is:
ip dhcp pool sdm-pool1
dns-server 63.251.92.193 64.74.96.242
Kevin Dorrell
Luxembourg
in general, you do not need to put the IP address of a DNS server into the configuration of your router. Try and take the following entries out of your configuration:
ip name-server 63.251.92.193
ip name-server 64.74.96.242
Also, change the access list 101, and take out these 4 lines:
access-list 101 permit udp host 64.74.96.242 eq domain any
access-list 101 permit udp host 63.251.92.193 eq domain any
access-list 101 permit udp host 194.74.65.68 eq domain any
access-list 101 permit udp host 194.74.65.68 eq domain host 217.x.x.x
access-list 101 permit udp host 194.72.9.38 eq domain host 217.x.x.x
and replace those with:
access-list 101 permit udp any any eq domain
GNT
Bronze
If you do end up removing the DNS servers from the router itself, also make sure to add "no ip domain-lookup". Otherwise, the router will still continue to attempt DNS lookups (trying to locate a DNS server via broadcast), and it will get very annoying.
But the problem here is that there are no DNS servers listed in the DHCP scope.
Bronze
As mentioned, you need to specify the DNS servers in the DHCP pool. So change your config to this:
Another option is run a DNS server on the router itself. In this case, the config would be:
ip dns server
dns-server 10.10.10.1
This method is especially useful if you have multiple ISPs.
Thnks Guys as soon as I enabled the DNS in DHCP and ran the ip dns server command everything worked perfectly.
135
