virtaul interfaces on 2821
can someone please help me to validate the following interface config:
interface GigabitEthernet0/0
description $CONNECTION TO LAN$
no ip address
duplex auto
speed 100
interface GigabitEthernet0/0.1
description $NATIVE_Data$
encapsulation dot1Q 1
ip address 172.20.1.254 255.255.255.0
ip nat inside
ip virtual-reassembly
interface GigabitEthernet0/0.20
description $CONFIG_CNTR$
encapsulation dot1Q
ip address 192.168.2.1 255.255.255.0
ip helper-address 192.168.200.254 {another DHCP server on HP switch trunked to cat3560 switch which is connected to the Cisco on GI0/0 as the voice switch}
ip nat inside
interface GigabitEthernet0/0.50
description $VOICE$
encapsulation dot1Q
ip nat inside
Q: do i need to give ip add to vlan 50 or i can just leave it part of the native vlan.
thank you in advance
Hall of Fame Super Gold
Re: virtaul interfaces on 2821
You need a VLAN ID for each encapsulation dot1q, and an IP address for each subinterface.
You do not need "ip virtual-reassembly".
can i do:
vlan 1 for example: 172.20.2.0
vlan 20 192.168.2.0
vlan 50 172.20.1.0
under int .20 i have an ip add helper to point to another dhcp server, is that the way to do it?
thank you so much for your help.
Yes.
Please remember to rate useful posts with the scrollbox below.
113
