11-10-2008 04:09 AM - edited 03-04-2019 12:15 AM
Hello
i need to separate two networks in my LAN, using router with one public IP address, is the concept of Virtual router will works here,
if so could some one give brief configuration assuming one router with static routing protocol.
thank you
11-10-2008 04:12 AM
Ala
Could you provide a few more details ie. you say you have one router with one public IP address and you want to separate 2 networks. What exactly do you mean by this.
What is your router model, how many interfaces does it have etc..
Jon
11-10-2008 04:20 AM
hello Jon
thank you for ur immediate response
i have Cisco 1841 router with serial interface and 2 ethernet interfaces, i want to separate 2 networks, i.e the Sales guys can not access those in Administration Dept,
through one public ip address asigned from ISP, is it possible for this separation through subnetting or Virtual router.
i hope i express my needs clearly.
thanks
11-10-2008 04:31 AM
Ala
Do you have a switch that your internal users are connected to. If so it is relatively easy to do what you want. So on your switch you would create 2 vlans
switch(config)# vlan 10
switch(config-vlan)# name admin_vlan
switch(config)# vlan 11
switch(config-vlan)# name sales_vlan
Then connect fa0/0 on your 1841 to one of the switchports eg. gi0/1 and on the switch
int gi0/1
switchport access vlan 10
connect fa0/1 on your 1841 to another of the switchports eg. gi0/2
int gi0/2
switchport access vlan 11
On the 1841 router
access-list 101 deny ip 192.168.6.0 0.0.0.255 192.168.5.0 0.0.0.255
access-list 101 permit ip any any
int fa0/0
ip address 192.168.5.1 255.255.255.0
ip nat inside
int fa0/1
ip address 192.168.6.1 255.255.255.0
ip nat inside
ip access-group 101 in
int s0/0
ip nat outside
then just allocate sales and admin PC's into their respective vlans on the switch using the "switchport access vlan ..." command.
Each admin PC needs it's default-gateway set to 192.168.5.1
Each sales PC needs it's default-gateway set to 192.168.6.1
The above config will allow your sales and admin people to access the Internet and it will also stop your sales people connecting to admin machines.
Obviously you will need to modify the IP addressing etc. to meet your needs.
Jon
